Question about The Video Cameras
The tape came unlatched from the spool on my Komelon 6100 100ft fiberglass tape. I'm have trouble reattaching the taope to spool. Not sure if I am missing parts or not How do you reattach tape?
SOURCE:
SOURCE: Error message: E03 Unit in Safeguard Mode - Remove and reattach battery
HI, ERROR CODE E03 MEANS THE THE TAPE IN YOUR CAMCORDER IS TOO SLACK, ALL YOU NEED TO DO IS EJECT THE TAPE & TIGHTEN IT USING YOUE THUMB LIKE I DID, ONCE I PUT THE TAPE BACK IN THE ERROR HAD GONE ( FOR EVER I HOPE!) GIVE IT A GO ANYWAY, HAYLEY X
Posted on Mar 21, 2007
  • 249 Answers
SOURCE: GE Nautilus - top spinner has fallen off
the rotor arm may be faulty
Posted on Nov 28, 2007
SOURCE: safeguard mode/remove battery & reattach
i have a handycam jvc gr-d53ag. now the device become error.
it says "in safeguad mode, eject and reinsert the tape.
i have done it still no progress. please help me with this problem.
i would be very appreciate it.
thx so much
Posted on Jan 24, 2009
Saaboheme
  • 76 Answers
SOURCE: How to reattach serpentine belt on 1999 saab 9-3
The Saab accessory drive (serpentine) belt is self-tensioning by means of a tensioning pulley. Excessive play means that the current belt is spent and must be replaced. It is a very good idea to replace the idler pulley above the tensioner pulley at this time as the bearings fail over time. You can get an aftermarket pulley of machined billet aluminum construction with a repalceable bearing race from Wazee Pulleys. This pulley is superior to the stock one in just about every conceivable way.
To remove the belt you will need a 1/2 inch socket extension bar that will fit exactly in the top of the tensioning pulley housing and a six mm allen key which you will use to lock the tensioner assembly into this position relaxing the belt. This site shows the proper routing of the stock belt and the routing procedure to bypass the highly failure prone center idler pulley if your car has that (yours should not), as well as the procedure to remove and fit a new belt. Note, the belts shown on this site are for the short-belt modification only. See also, this site for additional information. Another diagram is here with part numbers for the pulleys and the belt.
To remove the belt, you will find it best to remove the airbox to allow you more room at the top end to work. Also, jack up the car and remove the passenger wheel to give you access down below.
Posted on May 06, 2009
SOURCE: cigarette lighter came undone. how do I reattach?
I had this problem as well. Start by removing the small plastic plate by the emergency brake (Pull the brake up). It just pops off, Then remove the left side of the middle console that includes the cup holders and ash tray. It will loosen and you will have to manuever it to take it completely out - turn it sidways to get it out from the shifter, You will need to do this to get to the two screws holding in the front panel where the cigarette lighter is at. Using a phillips screw driver, unscrew the two screws at the very botton of the panel near where it would meet the center console. These screws are hard to get to but can be done. Once you have removed the screws, starting at the bottom, begin to remove the panel slowly as the wiring will still be attached. Unclip the emergency blinked power clip. The cigarette will have two plus that will clip off. The wiring will still be harnessed to the panel, By using a flat screw driver, you can push in the plug clips from the opposite side and the wiring plug will come out. Now you have the panel completely out. Position the cigarette holder in, the metal clip with the little handle goes to the rioght hand side in between the two plastic plugs.holding this all together, there should be a metal ring that will screw back in to hold the cigarette holder in place. once this is secure, plug in the three wiring clips and then plug in the wiring harness once you have the panel positioned to put this back in. once your wiring is back in re-mount the panel and put the two screws back in. Put in the center console molding and then put in the small molding by the parking brake.
I am a woman with no mechanical experience , so goes to show you that this is possible. Time it took me to repair - 30 mins including figuring out the panel screws etc.
Posted on Jan 14, 2010
The tape door wont close and pull tape down get code c32-11 and tried everthing and it says reattach power source
Error code 32:11 indicates a problem in the cameras tape transport sestem.This can be caused by several problems including the transmission gear in the tape mechanism not engaging properly, a defective clutch in the take-up spool or a faulty rotary mode switch. This will require disassembling the camera to repair and can be done fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Aug 21, 2011 | Sony Handycam DCR-HC28 Mini DV Digital...
I installed new correction tape, but there's too much play in it. It keeps unravelling. I have no idea how to tighten it up. When I turn the take-up spool, it just unravels it more without tightening...
Verify that you have installed the proper correction tape. The types of tape that can be used with this system are: Item 1030 - Correctable Film Ribbon, 1230 - Correctable Film Ribbon 2pack, 1031 - Multi Strike Ribbon, 1032 - Nylon Ribbon, 3010 - Lift-off correction tapes (to be used with 1030 and 1230 ribbons), 4010 Cover-up Correction tape (to be used with 1031 and 1032 ribbons).
Make sure that the correction tape is installed properly. Pass the tape through the left guide, behind the ribbon guide and out through the right guide. The rough side of the tape should face the platen. Attach the feeder spool to the pin on the left. Attach the take up spool to the pin on the right. Turn the take up spool counter clockwise until a small amount of tape has wound around it. Replace the cassette ribbon and close the case cover. Press [CODE] + [RESET] to move the carrier to the previous position.
Dec 27, 2010 | Brother ML-100 Typewriter
The tape broke and I am trying to put it back together so I don't lose the dictation
I have done this,carefully take the cassette apart,by removeing the screws,be sure and look at how it is assembled.
Remove both spools of tape.In the break area cut with a razor blade each sides of the spools so you have a smooth surface on the tape.
lay them on a flat surface,pointing towards each other,be carefull not to drop the spools.Put one (little) drop of supperglue on the tape,then put the other end of the tape on top,make sure the alignment is straight and you dont glue the tape to youre work area.Wait about five minutes,then reassemble. Works like a charm for me.
Oct 26, 2009 | Maxell MC-60 Micro Cassette (3-Pack)
My son broke the spool pin and I can not find a replacement. Is there a universal one that I can purchase?
You didn't throw away the piece did you? You can get a fiberglass repair kit at the automotive store, mix a little up and use it as glue. You may have to tape it together for a little while but then it will be like new.
Aug 05, 2009 | Singer 3116 Simple
Installing correction tape
The full spool goes on the L. side of the printer it goes thru guides on both sides of the printer and thr empty goes on the R.
Be sure the dull side of the tape faces the paper.
DickyO
Aug 28, 2008 | Brother ML-100 Typewriter
Changing correction tape on swintec 2600
Be sure the corr. tape not a tacky kind, then type some thing and correct it watching the mechinism th see which one turns and in what direction. Install the empty spool on that hub thread the L/O thru the guides with dull side facing the paper and then the full on the supply hub. there may be two or more guides depending on the printer.
Hope this helps
DickyO
Apr 28, 2008 | Office Equipment & Supplies
Typewriter change correction tape
I just finished replacing mine..You must first remove the ribbon for the typing, this simply lifts off. Then you must place the side with the corrective tape on the left side and the empty end on the right. While doing so, make sure that the ribbon of corrective tape is being placed around the knobs( one on each side) to hold in place. Then feed through and wind up till all the orange has disappeared then replace the Typing ribbon and this should complete the replacement
Apr 07, 2008 | Office Equipment & Supplies
Canon MV500
Perhaps this will help some. I realized that this problem occurs on my Canon Optura 30 (consumer mini DV) when the tape is fully rewound. Tapes that are not rewound seem to work fine. If this situation applies to you, try the following, and make sure that in the future you don't fully rewind your tapes! Fast forward your tape in a tape deck or rewinder. It should play in the camcorder now. If you don't have a machine to do it for you, you can manually advance the tape with a pointy object and a pencil (the eraser--or your pinky!). On the back of the tape, near the top (that is, opposite the side where the tape is exposed), locate the notch between the two spools (the "wheels"). The notch will have a spring-loaded slider inside, which you can hold open to free the spools. Otherwise they are locked in place and you can't turn them. Holding the slider open with your pointy object, insert the eraser in the right-hand spool (i.e., when the exposed tape is pointing down and the "spine" of the tape is pointing up). Turn the spool slowly counterclockwise, making a few complete turns, to gather up a short length of tape, enough so you have a few seconds' worth of timecode. Be careful not to leave any slack. You can turn the other spool a little bit (clockwise) to catch any slack; lift the cover on the exposed tape (by holding back the little release) to make sure it is tight. If you're not sure which spool to turn, it's the one that does *not* have a window on the front side of the tape. (If the tape is fully rewound, the spool in the window should look full.) Hope that helps, and good luck. In the future, I'll heed the common advice to use the camcorder playback as little as possible, relying on a tape deck for RW/FFand making sure to transfer material to scratch disks ASAP and then just storing that footage away in a shoebox!!!
Dec 11, 2007 | Canon Optura 20 Mini DV Digital Camcorder
REMOVE THE CASSETTE message
I realized that this problem occurs on my Canon Optura 30 (consumer mini DV) when the tape is fully rewound. Tapes that are not rewound seem to work fine. If this situation appears to apply to you, try the following, and make sure that in the future you don't fully rewind your tapes!
Fast forward your tape in a tape deck or rewinder. It should play in the camcorder now. If you don't have a machine to do it for you, you can manually advance the tape with a pointy object and a pencil (the eraser--or your pinky!). On the back of the tape, locate the notch between the two spools (the "wheels") near the top, that is, opposite the side where the tape is exposed. The notch will have a spring-loaded slider inside which you can hold open to free the spools. Otherwise they are locked in place and you can't turn them. Holding the slider open with your pointy object, insert the eraser in the right-hand spool (i.e., when the exposed tape is pointing down and the "spine" of the tape is pointing up). Turn the spool slowly counterclockwise, making a few complete turns, to gather up a short length of tape, enough so you have a few seconds' worth of timecode. Be careful not to leave any slack. You can turn the other spool a little bit (clockwise) to catch any slack; lift the cover on the exposed tape (by holding back the little release) to make sure it is tight. If you're not sure which spool to turn, it's the one that does *not* have a window on the front side of the tape. (If the tape is fully rewound, the spool in the window should look full.)
Oct 09, 2007 | Canon ZR100 Mini DV Digital Camcorder
Video Cameras Logo
49 people viewed this question
Top The Video Cameras Experts
Prudhvi Kumar
Level 1 Expert
D. E. Hev
Are you a The Video Camera Expert? Answer questions, earn points and help others
