SOURCE: Bissel Proheat Carpet cleaner
My Bissell had the same problem. The hand attachment does not use heated water. So I Found a clog of calcium and dirt in the heater portion of the unit. The heater is in the handle behind the red heater light on the front. Remove the upper portion of the handle. Remove the lower two screws in the lower portion and the parts will split apart. Remove the hoses and remove the heater. (mark where the wires go) The bottom of the heater can be removed with a screwdriver. The tubes leading into the heater is where the clog was but there was a lot of debris inside Make sure to clear it all and the hoses as well. I put it together and it works great.
SOURCE: Hoover Steam Vac Spin Scrub
Remove the brush block, is the shaft on it or broken off. Replace the block if broken off. Turn unit over, with brush block removed, handle tilted back, is the square hole turning, if not then the turbine is bad, this is what turns the brushes.
SOURCE: need help attaching vac hoses to shampoo couch.
Here are the instructions. But please be very careful and shampoo an inconspicuous area prior shampooing entire piece of the furniture.
SOURCE: electrolux lux vaccum cleaner hose and fitting/nozzle needed
Ladies! Go to vaccums24X7.com. They have more parts for older machines than you can imagine. They have good pix to help you ID your model if you can't read the worn spec plate. They have hoses for the 1970's-1990's old "iron horse" electrolux canister models. So does ebay and a few other sites...do a google search and you will find them. Sadly, Electrolux (the company) is more interested in selling new machines than supporting old ones...like everyone else these days. Still my old (1982) Silverado Delux really sucks, so much so in fact that it pulled the liner out of the old hose and would not pick up dirt as a result. A new hose is about $70....you can get a whole new vaccum at Wally-World for that, though as you point out they do not have the vaccum that the older machines do, but then the older machines are always needing work because of their age. I hope that helped you.
SOURCE: I HAVE A BISSELL PROHEAT CARPET CLEANER I
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
dygj
