A
Anonymous Posted on Apr 25, 2019
C480. How can I correct 'system initialise' error?
Have an error message on screen sayng NO HDD???
The system does give this message when the logic board can't access the Hard Disk.
Can be anything, from a complete over filled HD till a defect controller or just a corrupted first sector. Check what the user manual says about initialise the hard disk. If that won't help, consult a tech close to you. Btw. after an initialise or format you will have lost everything you recorded till now. So if something important is on the disk, ask a tech to get out the drive and recover the important stuff. This could cost you.
1helpful
Hooking hp photosmart c480
I would just connect it and see if Windows detects it. It may just work. I do not see a model C480 on the HP support site. Do not attempt to use the software that came with the printer.
Alarm activated and is unable to deactivate
REMOTE KEY INITIALIZATION For this type of key.
The initialisation of the FZV keys is required to establish the Lock/Unlock signal synchronisation with the GM V. The initialization procedure provides the GM with a key identification number and a "rolling code" for each key. If the initialisation is not performed, the GM will not respond to the key signals. Up to 4 remote keys can be initialised. They must be initialised at the same time. Key initialisation is only possible with the vehicle unlocked.
Procedure:
1. Close all doors and have all keys available.
2. Using key number 1, turn the ignition switch to KL R, then switch off within 5 seconds and remove the first key.
3. Within 30 seconds of turning the ignition switch to "off" Press and hold button #2 .
4. While holding button #2 , press and release ("tap") button #1 three times within 10 seconds.
5. Release both buttons. The LED in the key will flash momentarily. The GM will immediately lock and unlock the doors signalling a successful initialisation.
6. If additional keys need to be initialised repeat steps 3 - 5 within 30 seconds.
7. Switching the ignition to KL R completes the initialisation.
SERVICE NOTE:
The key memory function of the GM responds to the key identification number of each key. If the keys are not initialised in the same order prior to initialisation, the key memory functions activated by the keys will not be assigned correctly. Always initialise the keys in the same order.
REMOTE KEY INITIALISATION For this type of key.
The initialisation of the FZV keys is required to establish the Lock/Unlock signal synchronisation with the GM. The initialisation procedure provides the GM with a key identification number and a "rolling code" for each key. If the initialisation is not performed, the GM will not respond to the key signals. Up to 4 remote keys can be initialised. They must be initialised at the same time. Key initialisation is only possible with the vehicle unlocked.
Procedure:
3. Within 30 seconds of turning the ignition switch to "off" Press and hold the arrow button.
4. While holding the arrow button, press and release ("tap") the roundel button three times within 10 seconds.
5. Release both buttons. The GM will immediately lock and unlock the doors signalling a successful initialisation.
SERVICE NOTE:
The key memory function of the GM responds to the key identification number of each key. If the keys are not initialised in the same order prior to initialisation, the key memory function activated by the keys will not be assigned correctly. Always initialise the keys in the same order.
Zoom does not work on Megxon C480 does not allow focus
what is the screen say is happening
Jan 02, 2009 • Cameras
Megxon C480 Digital View Camera
I regret that there is no repair option in general for this type of thing.
Replacement is the only option
Jan 01, 2009 • Cameras
Megxon c480
I hit mine with a hammer It works well again now.
Apr 08, 2008 • Cameras
Sony CDX-C480 radio
I need the wireing dig for a sony cdx c480
Errors when Backing up information from hard drive.
I have several drives backed up and they work fine whenever they are imaged. anyway.. These drives are made for use in Windows and Mac enviorments. It is usually MAC users that have this problem.They are usually preformatted using fat32. because the drive is usually for storage fat32 is sufficent...but there are certain characters that fat32 dosen't care for...Do you have file naming scheme that uses odd characters? if so Those are the file names the error is refferring to. You may choose to reformat the drive using fat32(again) or NTFS(note fat32 has a better chance of data recovery just in case)your main hard drive might be NTFS. The rest is only important if you use a MAC Now if you have a MAC see below. How do I initialise the external drive for Mac OS X? Preparing the Seagate/Maxtor external hard drive in Mac OS X Mac OS X cannot mount a FAT32 partition larger than 137 GB (128 GB binary value). Our partiton is 160 GB (149 GB binary value). Since your external drive comes with a large FAT32 partition preinstalled you will need to initialise the drive to use it in Mac OS X. WARNING: Initialising or partitioning the drive will erase all data on the drive. If you have used this drive on another computer take the drive back to that computer and copy all data off of the drive before proceeding. When the drive was plugged into the Macintosh you probably noticed a message reporting an error that it cannot read the volume. At this point you have the option to initialise the drive. If you missed that message you can initialise the drive manually. Initialising the drive in OS X If you see the volume error, you can click the Initialise option. If you do not see it, then go to Finder > Applications > Utilities > Disk Utility. In Disk Utility: Select the external drive (149.05 GB). Be sure you select the correct drive before proceeding. If you have more than one 160 GB drive then be sure to select the correct one. 1. Go to the Erase tab. 2. Choose the type of partition (Mac OS Extended). 3. Type a volume label. 4. Tick the box that says "Install Mac OS 9 drivers". If this option is not selected, this device cannot be used by a computer running Mac OS 9. This option does not affect Classic. 5. Click Erase. 6. Read the prompt and Click on Erase again if you agree to erase all the data and you are sure the correct drive is selected. 7. The drive will now show on the desktop with a Firewire icon and the volume label as the name. Additional Information For more information on the FAT32 partition size limit in Mac OS X please read document number 107483 on Apple's support web site. For more information about formatting drives in Mac OS visit Apple's support web site. For more information about decimal versus binary capacity values visit our FAQ on the subject. Let me know what happens. Good Luck, Tim
Top Samsung Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
