Realistic cat.no. 20-109 Programmable FM scanning receiver. vhf:30-50/144-148/148-174 MHz UHF:410-450/450-470/470-512 MHz OK. Thanks for the answer. First I have to have the numbers to put in, in order to program it. Any one live in Missouri around Hermann area that knows the frequency numbers to program in?
It is a direct entry scanner so just enter manual and program then enter the frequencies you want. Press enter after each channel and press program again to advance to the next channel and repeat.
Testimonial: "thanks"
SOURCE: reception of vhf/uhf channels
You did not mention which set you have, so look for a small switch (usually on the back of the set) or go into the menu and set the TV to the "broadcast" or "tv" mode. If the set is in the "cable" mode, you will not get any UHF channels above 13.
SOURCE: Changing the Pro-49 Scanner from UHF to VHF channels,
Hi george - You can get the manual in sections that will tell you what you need to know plus you'll have it for reference. It's the way Radio Shack posts them. It's at this link:
http://support.radioshack.com/support_electronics/16429.htm
Or you can go to this site and send an email and they will email you the manual:
http://radiocollector0.tripod.com/id58.html
If this solves your problem PLEASE rate this as fixed. If you need more help just add a comment and I'll be happy to assist you further. Thanks.
Jeff
SOURCE: Is it uhf or vhf?
Model H01SDC9AA2AN:
HT1000 UHF 450-520 MHz, 8 Channel, 4 watt, Portable Radio
SOURCE: need codes for a Realistic Model#20-129 Pro-2024 Scanning Receive
Here;s a link where you can download and print the manual for your scanner:
http://support.radioshack.com/support_electronics/doc31/31323.htm
Bill B.
San Antonio
SOURCE: have a pro 2020 realistic
The memory on the unit is not retaining the frequencies. Check for a small battery on the circuit board like a button battery you would find on your computer motherboard. Replace the battery and reprogram the unit.
