Question edited for clarity. Question moved to Clock Radios.
Disabling the Alarm •? Press the AL1 or AL2 buttons repeatedly until the indicator is no longer lit.
ONN Digital Clock Radio User Guide - Manuals+ - manuals.plusManuals+https://manuals.plus > onn > digital-clock-radio-manual Jul 16, 2021 - ONN Digital Clock Radio User Guide ; 2 Information and Safety Instructions. 2.1 Important Safety Instructions. 2.2 ; 5 Clock & Sleep Timer. 5.1 ...
Hello Mike, it would be easier if you mention the brand and the model of your alarm clock radio, to be able to find the simplest solution.
I wait your answer
Greetings Franco Dosil
Hola Mike, seria mas sencillo si comentas la marca y el modelo de tu radio reloj despertador, para poder encontrar la manera mas sencilla de soluci?n
Espero tu respuesta
Saludos Franco Dosil
THE UNIT TO POWER Plug AC power cord to the AC wall outlet. Before switching on the unit, make sure that the voltage of your electricity supply is the same as that indicated on the rating plate. BATTERY BACKUP Insert 2 AAA batteries into the battery compartment. Be sure to observe the proper polarity (the "+" and "-" signs) as indicated inside the battery compartment. In case of power failure or interrupted AC power, the current time, alarm time settings, and stored radio stations are preserved in the memory of the unit using the battery back-up function. SETTING THE CLOCK 1. With the unit in CLOCK mode, press and hold the CLK/MEM button for about 1 second, the time will begin to flash on the LED display. 2. Press the ?/HR button to adjust the hour. 3. Press the ?/MIN button to adjust the minute. 4. When the correct time is selected, press the CLK/MEM button again to confirm. SETTING THE ALARMS 1. With the unit in CLOCK mode, press and hold the ALM1/VOL+ or ALM2/VOL? button. The ALARM time will begin to flash on the LED display. 2. Press the ?/HR button to adjust the alarm hour. 3. Press the ?/MIN button to adjust the alarm minute. 4. When the correct time is selected, press the ALM1/VOL+ or ALM2/VOL? button to confirm. 5. Press the ALM1/VOL+ or ALM2/VOL? button to select the ALARM sound mode - buzzer or currently set radio station. The alarm buzzer or radio indicator will light up. SNOOZE FUNCTION 1. Whenever the alarm (radio or buzzer) activates, it can be temporarily suspended for a short period of 9 minutes by pressing the SNOOZE/SLEEP button once. 2. The buzzer or radio will then automatically activate again after the 9 minutes SNOOZE period has ended. 3. This procedure can be repeated for up to approximately one hour. DIMMER FUNCTION Press the DIMMER button to change the brightness of the display. TURN OFF THE ALARM When the ALARM activates, press the ALM OFF/SOURCE button to turn off the ALARM. LISTENING TO THE AM/FM RADIO 1. Press the ALM OFF/SOURCE button to select the FM or AM mode. 2. Press the ?/MIN button or ?/HR button step by step to tune to the desired radio stations. 3. Press and hold the ?/MIN button or ?/HR buttons for approx. 1 second, it will start to search the next radio station in the direction of the search. The search operation simply finds stations with
