SOURCE: poulan Super 1800 16" chainsaw .
Hi dortfran,
My name is Dennis and I hope to be of assistance.
This sounds like a kink in the chain and I would try a new chain because this can be a very small kink and very difficult to find and straighten out. If you must put the chain saw in a vise by clamping the bar and run the chain back and forth from the sprocket to the bar grove under operating tension and locate the misalignment at the bargrove. Now you have located the problem but the fix is still sweat away, and with some luck you may be able to spring the chain straight and have the link flexable to opporate without a hitch.
Glad to be of assistance. Please rate the solution because i can learn from your rating.
Thank you
Dennis
SOURCE: what oil grade do I use in my 20hp huskavarna riding mower
use a good grade of automotive engine oil which is called 10w30 weight.
measure the amount of oil that you drain out so you will know approximately how much new oil to put in. then check your dip stick and adjust to get the exact amount of oil.
SOURCE: bog when trying to mow
you are cutting to much grass & it isn't kicking it out fast enough out of deck which will bog it down it might help if you clean out the bottom of the deck & also dont cut really low if grass is really tall also cutting wet grass will aslo cause the bogging if i can further help e-mail me wade at [email protected]
SOURCE: Mower deck will not engage.
you have sheared off the keyway either on the mandrel or pully on the engine
