SOURCE: HELP!!! Help wiring new motor for CKL60-1
Thank You
SOURCE: CAN ANYONE HELP IM TRYING
if you go on google enter clarion ab213r wiring diagram
and it should tell you what every wire is.
also enter your vehicles info and look up the wiring diagram for that also
it should be easy from there
SOURCE: I just purchased an fse1028sf
Hi, this is a different wiring diagram then what you have . The 2 brown/wht wires are for the run cap only. Black and white are t-1 and t-2. They sold you a motor that takes its own run capacitor to run it with just both brown wires. Take the diagram from the new motor back along with your original. They will give you the right run cap to go with this motor. Yes, the red wire is power to fire your existing cap and old motor. You will need another cap to run this motor. Don't put the 2 brn/white striped wires on the old cap! They have to be alone on there own run cap. Go back to the parts house and they will show you very fast the wiring diagram and give you the cap. This is a very easy fix when they give you what you need. Keep me posted and ask them to give you what you need to run the motor. A 5 uf run cap perhaps?
Keep me posted.
Shastalaker7
