SOURCE: aux cable snapped of inside external Audio port (AUX)
I have a 2007 CRV which had the same issue. I fixed this by:
- first removing the AUX port cover by carefully prying it up from both the rear-facing and front-facing edges. Once done, this exposes the AUX port mechanism itself.
- Using some needlenose plyers, I pulled out the AUX port component. It simply slides out.
- The trick now is to PUSH the broken piece out of the inside of the port. To do this, I first removed the "cover" that is covering the end of the port (opposite from the opening to the port). Be very careful with this step as you don't want to break the cover. It's very thin plastic.
- Once this cover is removed, I used a pin to push the piece that was lodged inside back out of the opening.
Reassembly was the opposite of this and was quick.
Hope that helps.
- Dave
