SOURCE: 2000 durango 5.2 cold starts, engine stalls or rpm surging
i know this may sound stupid but if your battery is old or a little weak on this vehicle the idle air control solenoid will act speradicley hunting for were it should be and the vehicle will stall.replace battery
SOURCE: 88 pontiac 6000 shudders and stalls after approx. 30 min. driving
What was replaced in the tune up? Usually the coil paks cause these types of issues. Also fuel filter or fuel pump will allow enough fuel to start and sputter like you describe.
SOURCE: car won't start, wait 15 min. will start but kinda backfires.
possible ignition coil pack breaking down...unit cools off them fires plugs again...fuel pressure is a concern also ..possible failing fuel pump
SOURCE: stalls while driving; wait 40 minutes it starts
need to check fuel pressure when its not starting. Also you may have a ASD or a Fuel pump relay going bad. Swap with know good one like the AC or the horn and test.
