Dryers Logo
n
noushad Posted on Apr 24, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Samsung dryer dv665jw moter not work - Samsung Dryers
Darrin P. De May
Level 3:
Master:
  • Master 665 Answers
  • Posted on Apr 24, 2019
Darrin P. De May
Master
Level 3:
Master:
Answers
665
Questions
0
Helped
153315
Points
1951
Then you should replace it:
https://www.partselect.com/Models/DV665JW/MFGModelNumber/XAA-0000/
2 Related Answers
Anonymous
  • 1056 Answers
  • Posted on Aug 04, 2009
SOURCE: heating element has stopped working just 2 days
use a multimeter to check the continuity of the heating elements. if there is an open, replacing it will solve the problem.
Anonymous
  • Posted on Jan 02, 2011
SOURCE: Hi, I have problems with SAMSUNG
you probably have a broken wire in the heating element. located on the back of machine, top right corner, behind panel.
remove the two screws
1helpful
Samsung Dryer DV665JW has no Power. I already checked the plugs and Breaker system, they are okay but nothing happens when I press the power button. It is 4 years old. Is it worth repairing ?
First, when you say "no power", is the front panel display totally dead? If so, and you're sure 240v is getting to the back of the dryer where the power cord connects, then its most likely the main board has been blown--did you have a power outtage recently? They are notorious for damaging circuit boards. If the dryer lights up but won't do anything when you push the start button, check the door switch--it's a safety feature that won't allow the dryer to run with the door open. There are also thermal fuses inside which, if open, will kill the power. BTW, yes, the dryer is worth fixing--the cost of a repair won't be near what a new dryer will be.
What does E3 mean on my Samsung dryer
For most Samsung dryers, an E3 error could mean that the dryer tub is too heavy, the vent is clogged, the thermistor is faulty, the control unit is faulty, or that there is a loose wire at the main control unit.
If you were drying a very heavy item or too many articles, try a smaller load. Check the dryer vent to make sure that it isn't blocked or clogged with lint. (I've seen the flap on a vent shift and fail to swivel properly.) Next unplug the dryer and pull it forward. Remove the back from the top (control area) and check that the wiring harnesses are fully seated. You may want to check for corrosion or damaged wires. Next check the resistance of the thermistor (mounted on the blower wheel). (Assuming a room temperature environment, the resistance should be ~6 kilo ohms.) If the thermistor is faulty, it needs to be replaced. If the above steps don't solve the problem, then the control unit needs to be replaced. http://www.searspartsdirect.com/samsung-dryer-Parts/Model-dv665jwxaa0000/1482/0151200/50039961/00001.html has the parts breakdown and many parts are available.
If the dryer is still under warranty, contact Samsung for the repair. I hope this helps.
Samsung dv665jw error code e5
Please find list of error codes and their remedy in the link below
Error codes
1helpful
No heat model dv665jw/xac
Element or thermal trip on element, you will need to test them with a meter, as to which one, But if thermal trip gone, why, could be element on way out.
My drum on my dryer is not yurning but all else seems to be working fine i have given the drum a push it then turns but when it stipos it will not move again
the belt could be bad or the moter if its the moter u will probably hear humming but the only way to really find out is to take the dryer apart to get to the moter and look at the belt
2helpful
2answers
Hi, I have problems with SAMSUNG Dryer Model # DV665JW/XAC. It does not dry clothes at all. Could u please help!!! cheers, lucina
MY MODEL IS DV665JW/XHC DRYER THERE IS NO HEAT
if it is a condenser type dryer you may find the condenser has not been cleaned and this suffercates the unit and over heats. to protect the heater element there is a thermostat cut off which has more than likely blown which breaks the electrical circuit. so this would need replacing which is found near the heater element at the rear of the unit. then clean your condenser.
hope this helps
1helpful
Just bought the DV665JW - doesn't get hot or heat my clothes
check power in your house,,,,if it runs on electric it is possable for the motor and timer to work but the heater not to as half of your 240 or 220 line is dead http://www.washerwizzards.com
Heating element has stopped working just 2 days
Aug 04, 2009 • Dryers
53helpful
4answers
Samsung dv4006 dryer belt
Possible replacement belt quality problem for the Samsung DV4006 / DV4006J / DV4015J / DV665JW and the Maytag MDE2400AZW dryers:
The original belt for the Samsung DV4006 / DV4006J / DV4015J / DV665JW dryers is a Megadyne 1975 H7. The part number is DC66-00121A, but when ordered, a Dongil 7PH1975 belt may be shipped instead of the original Megadyne. The Maytag MDE2400AZW dryer uses the same belt. The part number is 35001010, but when ordered, a Dongil 7PH1975 belt may be shipped. It seems that the Dongil belts are inadequate for these dryers. They delaminate and may fail prematurely. Even new, they cause a thumping sound each time the seam goes over the motor pulley. Other than Megadyne, another good belt is the Hutchinson 1975H7. The appliance part number is 1258288107.
Where to get an original Megadyne 1975 H7 belt:
eBay member 'appliance-parts' in Colorado, USA has emailed me that their Samsung DC66-00121A belts are Megadyne. Website: http://appliancefactory.com Email address: [email protected]
eBay member 'ladydi1975' in Ohio, USA has emailed me that their Maytag 35001010 belts are Megadyne. eBay store: Discount Appliance Parts.
Where to get a Hutchinson 1975H7 belt:
eBay member: 'zodiac300_0' in Brighton, United Kingdom. I have ordered a 1975H7 belt from them and received a Hutchinson.
Other possible causes for belt failure:
--Motor pulley designed too small. The belt may be flexed beyond it's minimum rated radius.
--Excessive heat in the dryer due to lint in the vent line or vent line too long. The Dongil belt may be less heat resistant than the Megadyne.
--Worn drum bushing DC66-00062A.
--Metal burrs on the steel motor pulley. Deburr by inserting a small screwdriver in each groove while the motor is turning without the belt.
--Belt on the wrong track. The motor pulley has nine grooves and the belt has seven ribs. The belt must be in the middle. It's easy to place it one groove forward or backward by error.
--Small scratches on the drum where the belt contacts it. The scratches may be like small knives and damage the belt. Sand with a fine sandpaper.
--Idler pulley damaged or bearing worn.
How to replace the belt:
--Remove top cover.
--Remove vent panel (in back).
--Unclip door switch from front panel.
--Disconnect wire harness from door switch.
--Unscrew panel left of control console (from behind the panel).
--Unclip panel left of control console (from behind the panel).
--Unscrew control console.
--Unclip plastic panel on bottom, front
--Remove screws behind door. Remove door.
--Unscrew large front panel, remove.
--Inspect vent line for lint buildup, drum bushing (back of dryer) for wear, motor pulley for burrs and debris, drum for scratches, and idler pulley/bearing for damage.
--Vacuum all lint.
--Install belt around drum, idler pulley, and motor pulley. The ribbed side of the belt contacts the drum. The flat side of the belt contacts the idler pulley. Press on idler pulley to stretch the spring, and line up the seven belt ribs in the center of the nine motor pulley grooves.
--Reassemble.
Top Samsung Dryers Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
