SOURCE: air condit. runs for ten minutes , shuts off and
You should first look in the instruction/operation manual usually in the back pages for trouble shooting or code faults (errors). There should be a list of faults such as E1, E2, E33, E44 etc. and an explanation of each code. If you cannot find this info, call the manufacture ; they will tell you exactly what the E1 fault code stands for and possibly what will correct it. Ask for technical support. The fact that it runs for 10 minutes and stops; if you unplug it or turn the control to off, will it start again when you reenergize it ? This could indicate low voltage from the electric source. Are you running it with an extention cord or is the electric circuit line a very long run and robbing power before it gets to the unit? Have you checked the filter so that it is clean enough for good air flow, otherwise the unit will detect the low air movement from a dirty filter and shut itself down.
SOURCE: my portable air condition will not work when
HI.An E1 codes means that you need to clean the filter.Need toclear out debris that. May block the flow of air.
