The most probable thing wrong is going to be a blown fuse on the control panel. To check for that,
disconnect power to dishwasher by turning off circuit breaker ,remove torx headed screws from around the inner door,seperate inner/outer door panel,remove the plastic cover off of the control panel, and use a multimeter set to measure ohms and remove the 2 wires to the thermal fuse and check for continuty with ZERO ohms resistiance on the thermal fuse. IF the fuse is blown the meter display will show OL or the display will not change...if using a meter with a needle the needle will not move if the fuse is blown..if the fuse is good the display will show
0.00-1.00 on a digital meter and the needle will swing all the way to the right and stay there on analog meter. If the fuse does check to be good the most likely cause of the diswasher not running will be the door switches. Here is what the fuse looks like
Good luck i hope i helped you to fix your dishwahser,
GENE
