I think your model number is LC-32LE700UN. What is your video source? The CC button will only work for captions from the TV source (RF) OTA or cable without a converter box. For video from any set-top box (for example, an HDMI source), you'll have to enable the captions at that device. Depending on the device, you may have to navigate through the menus, rather than use quick CC button. On my IPTV box, I can enable the closed captions by entering the setup menu using a pass code provided by the ISP. Then I have to enter the Audio section of the Hardware menu. On one satellite system some years ago, I had to enable captions for both TVs at their primary receiver. This let their hearing-impaired uncle watch TV when he visited and watched a second TV.
Sharp has the documentation for the LC-32LE700UN here: https://www.sharpusa.com/Support/ProductDetail.aspx?model=LC-32LE700UN . The current link to the manual is http://files.sharpusa.com/Downloads/ForHome/HomeEntertainment/LCDTVs/Manuals/tel_man_LC32LE700UN.pdf .
I hope this helps. Please add a comment with the TV source for additional information about the Closed Caption for that source.
SOURCE: Sharp Aquos LC-C32344 Manual
SHARP 65 LC65D90U 1080P HD LCD TV
I like this a product very much
muchhttp://www.eboyvip.com/goods.php?id=646
SOURCE: Sharp Aquos LC 37HV4U - problems with AVC
I have a fully functioning lc37hv4u box & cable that I will sell for 200$ my lcd got cracked. let me know [email protected]
SOURCE: LC-37AF3X Sharp Aquos KCD TV
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The
internal circuits are jammed because of electrostatic
charges accumulating on capacitors, or because of a wrong voltage read
by the main chip on your monitor controller board. this started the
protection circuit.
2 The protection circuit detected a wrong
voltage or abroken contact, identified an internal fault and kicked in
, starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay
particular attention at inverter and power board, power board can be
inspected looking for bulged or leaking capacitors, then tested with a
multimeter. The inverter is more difficult to test , there is need to
read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
SOURCE: sharp aquos no sound through hdmi
Reset all audio factory setting.Tries unplug,replug it well work,if ur backlight video board it still good.
Testimonial: "worked like a charm thank you so much, i was about to throw in the towel and get a new tv, now i don't have to thanks again"
