If your guardian looks like the one in the video then it should be easy to change if you can reach it. https://www.youtube.com/watch?v=4U74bKZOPZ0
SOURCE: fuel supply
no. the generator fuel is gravity feed.
you can install a fuel pump, but then you going to need additional wiring and hardware.
SOURCE: guardian rv generator
Your control board is faulty. Try to power up the ingnition coil as well as your fuel pump. If this does not get the engine running then you have major engine problems.
SOURCE: I have a new Guardian 40G generator that won't
Try to measure the voltage at the connector when trying to start.
If it is 12 V and the engine does not start - disconnect it and try again.
Have in mind that you must have protections (Shut down):
and this valve may be responsible for them.
SOURCE: I have a guardian quietpact
This is likely a problem with the voltage regulator or the wiring. If this unit has brushes/sliprings for field excitation check the condition of those.
SOURCE: My Guardian generator Quietpact 40G makes a
if the noise is coming from the solenoid attached to the top of the starter replace it for the windings are shorted out causing the noise you hear
