I have closed the vents as far as they will go. there is wood and water in it. there is no extension chord it is on same outlet as deep freezer
SOURCE: oil and water on floor near upright freezer
Possible you have a sealed system problem, although you state it is working now. Maybe an overflow from drain pan is why there is water again.
SOURCE: GE GSS22 refrig wont get cold, freezer does.
Hi, it's possible you have a defrost problem, to know if you have a defrost problem, you should unplug/disconnect refrigerator, remove your produce, leave doors open, for faster defrost, clean and leave unplug/disconnected for about hour, be cautious you will get excessive water from defrosting. let freezer defrost completely, then plug/connect refrigerator, let it work/run for an hour, if it's o/k, put back your produce, if it work good/ o/k for 3 to 4 days and start doing the same thing, you got a defrost problem, defrost problems are caused when excessive ice build up on your evaporator, two things could cause a defrost problem. (1) excessive moisture/ hot air entering refrigerator, hot days,hot foods, regular opening, to close heat source, range/ oven. in cases like that, cleaning of refrigerator will normally solve that problem. (2) faulty defrost heaters, defrost thermostat , located in back of freezer side, you will have to remove shelves and back panel, to get access to it,also check your defrost timer and speed of fan, but first disconnect refrigerator, clean and try , before changing any parts. it could just be excessive moisture. always remember to disconnect your refrigerator before attempting any repairs, let me know what happened, then i could tell you exactly what's problem. good luck
SOURCE: Freezer works fine. Refridgerator wont get below 60 degrees.
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
