K
Ken Leamy Posted on Apr 23, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Went to turn on my Tascam 302, all it does is buzz. If I press a button it looks like it says "err 1". Anyone know what the problem is?
I have not turned this unit on in years. Also when I open the decks the guide pins are spinning
Franco Dosil
Level 3:
Top Expert:
  • Tascam Master 10,542 Answers
  • Posted on Apr 24, 2019
Franco Dosil
Tascam Master
Level 3:
Top Expert:
Answers
10542
Questions
0
Helped
377525
Points
178965
Hello Ken, I was looking in the manuals of Tascam 302 and it does not refer to "ERR 1", it appears "ERR 2" and "ERR 3"
From what you describe, you may have a power supply problem in the low signal area, or have some of the mechanisms out of point, so you can see that the axes are turning
If you have technical features, try disconnecting the multipin cable that feeds the mechanics and check if the noise continues, if it does not appear, go reconnecting each mechanism separately and looking for which generates the problem, could be both, at that point I suggest, consult to a specialized technical service
I hope my comment has served you
Greetings Franco Dosil
Hola Ken, estuve buscando en los manuales de Tascam 302 y no hace referencia a "ERR 1", aparece "ERR 2" y "ERR 3"
Por lo que describes puede ser que tengas un problema de fuente de alimentaci?n de la zona de baja se?al, o tengas alguno de los mecanismos fuera de punto, por eso observas que est?n girando los ejes capstan
Si tienes conocimientos t?cnicos, prueba desconectando el cable multipin que alimenta las mec?nicas y verifica si continua el ruido, si no aparece , ve re conectando cada mecanismo por separado y buscando cual genera el problema, podr?an ser los dos, en ese punto te sugiero, consulta a un servicio t?cnico especializado
Espero te haya servido mi comentario
Saludos Franco Dosil
5 Related Answers
Vista Electronics
  • 1694 Answers
  • Posted on Oct 09, 2007
SOURCE: RCA HDTV D40W20: Turning it ON
Probable bad IHVT aka flyback transformer. Check your service # on back of set== D40W20Byx1 uses part # 270125. D40W20yx1 uses part # 259296. Please let me know! T.
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Sep 28, 2007
SOURCE: 1800 XL JVM1860BD - won't work
It sounds like your controller may be failing. Or it could be an electrical line problem. Any other electrical itmes giving you trouble? Has anyone measured the voltage level of your power line? It should be around 110-125 volts AC. If it's significantly lower or higher, you may have a bad connection in your breaker panel or in the wiring leading to the home.
Anonymous
  • 1294 Answers
  • Posted on Dec 03, 2007
SOURCE: Err Err err err err pau
Press "stop" & "cancel" together for over 10 seconds to clear the display; and continue your..........
And rate me pl.......
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Mar 06, 2009
SOURCE: Kenmore microwave making loud buzzing sound.
Grubhead
Grubhead
  • 5755 Answers
  • Posted on Aug 06, 2009
SOURCE: Tascam 122MKII - press play no sound, meters don't move
Look for small leaver or any contact switches. They might have become bent out of shape or broken, or have dirt in them, cutting off the sound. Also check the leads coming from the head, they might have become detached or at least you can trace where they join the PC board. If you touch where they join you should get a buzz on either channel.
Tascam dr-07 when I turn on the display reads system err 50
Kennedy, Do hard reset by hold down the track edit and up arrow keys simultaneously while powering up. It will re-initialize the disk and ask you if you're sure you want to. Ans. yes using the (yes/enter) key, and the unit will re-boot itself and return to the welcome screen as loaded from the factory.
PRESS THE HELPFUL BUTTON
https://www.google.ca/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&cad=rja&uact=8&ved=0ahUKEwji99_noujKAhXKJB4KHctTDsIQFggjMAE&url=https%3A%2F%2Fwww.educ.cam.ac.uk%2Fservices%2Favs%2Floanstock%2Fmanuals%2FUser-Manual-Tascam-DR-07.pdf&usg=AFQjCNEmPJ4OCw7_ULc8zPDMmrafuRMIQw&bvm=bv.113370389,d.dmo
Tascam DR 07mkII Owner Manual Page 116
Amazon com Customer Reviews Tascam DR07 Portable Digital Recorder
1helpful
Shows err- 3 on power up.
I think it is refering to an external control device such as a wired remote. You might try unhooking external connections and then re-hooking them and then booting it back up. Good Luck
Shows err 3 on power up.
It could be belts or internal cam motor contact sensors. The transports that Teac sells are not direct replacements and DO NOT WORK.
Tascam 302 Tape Deck - When I press play it rewind/fastfoward
There is either a cam belt that is lose or the flywheel assist can not move the head base due to hardened grease. It needs to be serviced.
3answers
On my Tascam 2488, the Stop, Play and Record buttons have been getting harder and harder to press and activate. Today I can't get them working at all no matter how hard I press. I opened the unit up, but...
I got the same problem. Also, the headphone jack on my Tascam 2488 is going bad. Only the right headphone will work most of the time. Anyone know a remedy/ solution for this?
1993 MAZDA MX 6 STEREO PROBLEM
If you enter the wrong thing 3 times I think your radio is useless
  • Press SCAN and AUTO.M until bars are displayed.
  • While the bars are displayed, input the code number by pressing the channel preset buttons 1, 2, 3, and 4. Press 1 for the first digit, 2 for the second, 3 for the third, and 4 for the last. If you number is 2547, press 1 three times, 2 six times, 3 five times, and 4 eight times. If the dispay goes off while inputing, begin from step 1.
  • Press SCAN and AUTO.M approximately 2 seconds and 'code' is displayed. 'code' will flash for 5 seconds, then disappear to indicate that the system is operable. If 'Err' appears, begin from step 1.
  • !CAUTION: Three consecutive errors will activate the antitheft system, and the audio unit will be completely inoperable and 'Err' will flash. When this happens, the unit must be replaced by an Authouized Mazda Dealer at the owner's expense. Do not allow unauthorized persons to attempt to input a code number.
    PocketStudio 5 Error - encDSP Init Err
    I turned off the unit, then while holding down rew and record buttons at same time, turned on unit. I don't know why, but it worked.
    My Tascam DR-1 digital recorder will not turn on
    To initialise the Tascam DR-05:
    Press and hold the + button and the Mark button while turning on.
    Thanks
    5helpful
    4answers
    Tascam pocketstudio5
    Hello tasbones and razzledog !I expect the following will help you solving the problems with the pattern file of pocketstudio5 (TASCAM):You need the original CD-ROM which includes the pattern file with many different drums and sound stuff. You have to put these data on a formatted cf-card (everytime again if you will use a new card) !This info comes from a german musician who had the same problem 5 years ago.Try the following Link of TASCAM where you can download the manual, an update and the PATTERN FILE !www.tascam.de   --> "Support" --> "download" --> "nicht mehr hergestellte Produkte" --> "pocketstudio5"If this will not work, give me a sign - I will try to send the data to you via mail.freewood/Berlin, Germany
    Top Tascam Audio Players & Recorders Experts
    John
    John
     Grubhead
    Grubhead
    ZJ Limited
    ZJ Limited
    Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
