Please help as to how this could be solved?
Sounds like you have a Keurig. My question to you is this... Did it suddenly become clogged from daily use? If so... Your Keurig may not be good anymore but, if you've had it stored and tried to get it to work again, I've had the same issue. Just run some vinegar through the machine. If you're unsuccessful you can try putting your finger over where it's going back into the reservoir and their baby enough pressure to push whatever's in there out. I did exactly that with mine. Good luck
SOURCE: Saeco Coffee maker container is leaking
OK, I finally called Saeco. There are about four rubber rings that you need to get. The one for the water resevoir is a big thick black ring and once you get it and look at the new and the old, you can see why it is leaking. Anyway, fixes it no problem.
The overflow in the drip tray? There are two rings in the back of the machine that will fix that problem. Problem? I got them, but haven't put it on there because it very hard to get in there.
Last one, the ring around the coffee puck maker (what do you call that part) It's the piston that catches the coffe and raises up to tamp it down, then holds it as the water goes through. ANyway, big ring around that. If you aren't getting a nice crema on top, that ring will cure that.
I saw get all four, replace them all at once and then descale the coffee maker and be done with it. You'll be working like new in a few hours or maintenance. For most of us, it's been like 3 years anyway, time to do it.
Lastly, when you call Saeco, (Pronounced I found our SA Yey Co) ask for the directions for cleaning out the grinder. Even has notes on how to get it back together with all the adjustments in the right spots.
The rep on the phone says she likes this model better than most fo the new ones.
SOURCE: water leaking out the bottom of the coffee maker
If it leaks DURING brewing, you may have to decalcify it (aka, run through a cycle of 4 cups vinegar, fill to the top with water, 2-3 times and see if it helps).
If it leaks before you even start brewing a pot of coffee, something is broken on the inside of the coffee maker, and I would recommend contacting Waring--they may be able to get you a replacement coffee maker (and if you're under warranty, usually a replacement would be free!).
Their phone number (according to their website, www.waringproducts.com ) is 1-800-4WARING (1-800-492-7464)
Good luck! :)
SOURCE: Tassimo machine leaking water underneath
I'm having the same problem with my machine. I rang the Tassimo careline and they told me to descale the machine but, so far, this has only made matters worse. I'm now going to take it back to where I got it from because it's still within its warranty.
SOURCE: Saeco Odea Go - Hot water leaks from bottom of machine
That's leaking from the hoses coming out from the boiler,if the machine is new it should be still under warranty, may have to take it back to the service center.When making coffee the lines are under pressure and the water never have a chance to pass through the ground coffee.
SOURCE: Dolce Gusto coffee machine hot water not flowing
use a solution of Bicarbonate of soda to clean scale from delivery pipe 1 tsp in 200ml
Please rate my help++++Thanks for using FIXYA
