Question about Home
I have a Thomas Byrne Grandfather clock that is chiming 1 Hour out of sink. Please tell me how I can correct this. Thank you. Ron.
    Sergeant:
  • 200 Answers
Someone moved the hour hand, probably when changing the daylight saving time. The minute hand turns the mechanics of the clock, the hour hand is floating.
Posted on Jul 12, 2019
4 Suggested Answers
SOURCE:
george6roble
  • 49 Answers
SOURCE: Halo Grandfather Clock won't chime hour
In my eyes there are two kinds, ones that are a real grandfather clock that runs on gravity using a series of weights and gears with different counterweights for chimes and running the clock itself, and there are the show pieces that look like a grandfather clock but run on newer tech and electronics. If a real one then would try first pulling the weights to the top. They are usually shaped into a pinecone or something. If weight is at bottom them have to pull corresponding chain with weight till the weight is at the top of case. As "time" goes by the weights lower. You should have different counterweights for the clock, chimes, dancing figures and whatever else it may have. All the weights move at different "speeds" so you have to keep an eye on them to make sure it keeps correct time. I would recommend consulting the manufacturer if possible. There are so many kinds out there is really hard to tell by such a short video.
Posted on Dec 16, 2014
  • 37 Answers
SOURCE: Gazo Rancho Santa Fe Grandfather Clock won't chim
Check the wires in the back.some times the get corrodes.
Posted on Dec 18, 2014
SOURCE: I have a Seth Thomas
The next time it chimes multiple times turn the hour hand clockwise until it is pointing at the number of times it gonged. Next take off the dial nut off (make sure to put it in a plastic bag because they can be hard to replace) and turn the minute hand until it chimes signaling 15 minutes after. Now put the minute hand back on pointing to 3 o'clock and replace your dial nut and you are all set.
Fix Clock That Gongs Wrong
Posted on Feb 24, 2017
It wont chime on the hour
Basic assumption... The chimes know what time it is...!!
FORCE NOTHING...!!
From page 10 of owners manual below (MINUTES):
EXAMPLE: Clock chimes at 1:10 but should chime at 1:15.
Step 1: When clock chimes at 1:10 stop the pendulum and record the time of 1:10.
Step 2: Carefully remove the small nut....
(Hour procedure is on the SAME PAGE (10).
WARRANTY INSTRUCTION MANUALS
Apr 19, 2016 | RIDGEWAY GRANDFATHER CLOCKS Ridgeway...
Dec 17, 2014 | Home
Dec 16, 2014 | Home
I have a Coaster Grandfather Clock. I lost the manual. I need to find out how to reset the chimes.
Hi Wanda....call Coaster Furniture national call center -
1 877 221 9666. They can tell you how to reset the
chimes. Ask them for a manual.
Regards,
Dennis
Oct 21, 2014 | Coaster Furniture Large Traditional...
How to adjust Grandfather clock that chimes one chime less ?
Move the hour hand counter clock wise to 10 o'clock. Then turn the minute hand clock wise to set the correct time.
Main Page
Oct 04, 2014 | Home
Thomas byrne longcase clock
When was the last time it was serviced? It probably needs a good cleaning and/or oiling.
http://usedclockparts.com/8-clock-movement-repairs/39-how-to-easily-clean-and-or-fix-your-clock-movement
Mar 26, 2014 | Home
I have a Seth Thomas Grandfather clock with three different chimes and chimes at every 15 minutes. The problem is it is chiming 2 hours shorter than the actual time. Example say it is 11:00, it is...
Thanks for contacting FixYa.
I wish I had an aswer for you but I dont. Here is a link for a repair man that has an 800 # toll free to call for estimate.
http://clock-repair.net/site-map/seth-thomas-clock-repair/
Best regards. Jewel
Sep 13, 2010 | Watches
Have a Galleria Grandfather clock thats chimes are off. How do I get them correct? Bought it at an auction and did not get any information with it. It chimed correctly in the beginning.
I suspect that the mechanism needs cleaning.
Take a look inside and if there is the slightest sign of dirt (particularly on the striking mechanism) then it should behave properly after cleaning.
May 01, 2010 | Watches
Home Logo
55 people viewed this question
Top Home Experts
US Parts Center
US Parts Center
Donni Steen
john h
Are you a Home Expert? Answer questions, earn points and help others
