SOURCE: MXP100 Software Needed
I used to sell eDigital products, particularly the Treos. I have put Music Explorer plus the MXP 100 firmware update on my webspace for a limited time: Music Explorer: http://benedict.fastmail.co.uk/Music_Explorer.zip MXP100 firmware: http://benedict.fastmail.co.uk/MXP100_V2_0_0_2.exe Here is a shameless plug for my two auctions for a brand new Treo 10 and 2GB MXP100: http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=220066898512 http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=220066956306 Cheers, Benedict.
SOURCE: copier with scanner:programming email addresses
step 1...finding ip address of copier.....On computer if running xp, go to start then control panel then printers and faxs, here you should find a icon that is for your copier, right not left click on it, then choose properties, then a box opens select third tab up the top named ports, a new box appears....now in this box there will be a tick in a tiny box near where is should say IP.......just place mouse near this tick leave still and on screen will display IP 111.111.111.111. ....write your version of that number down.(???.???.???.???) close/ cancel all windows that we have left open. (this procedure can also be done via copier keypad as instructed previously)
step 2 openning up copier webpage....Open up the program that you use to explore the WWW, usally explorer... like this window you can see now in front of you up the top it says www.//fixya.etcetc ... in that spot put in the number you wrote down like 123.456.789.111 nothing else...hit enter and you will browse to copiers web page that has the settings for saving addresses in copiers address book.
If this doesn't work then you do not have the rights on your pc terminal or your not running xp or your computer or your pc is not set up to print to this copier, if this is the case then it needs to be done at the server that is connected to this copier.
SOURCE: Won't PDF to email
I had the same issue when migrating between exchange servers. basically the scanner settings were pointing to the old exchange servers IP. I set that to the new IP and it resolved the issue.
SOURCE: Emails not reaching destination although they are in 'sent box'
This can be due to your destination server's security settings that are set to reject incoming Yahoo emails, that were largely used by spammers in the past years.
What you can do is call the person you are trying to reach by email, and ask him if there was any security settings set by his company or ISP.
Frequently companies are using "blacklists" in order to block junk mail. You are then in a "false positive" situation that is hard to solve. Try to send from another email adress to see if that still happens.
Hope this helps
