This Orient Ultron Series model OS-19K7 WD IN-HC has been throwing F1 error code since its installation 3 years ago. Sometimes it gives this error after 10 minutes of run time while at other times it would operate for days and then give this error. The refrigerant pressure is tested to be accurate. When it displays F1, the indoor fan keeps running but the compressor and condenser fan stops. I can't find any troubleshooting documentation online. All advice is appreciated.
SOURCE: Samsung Ac compressor stops after 20 minutes and fan keep running
eventually,cycling process is doing done if the thermostat sense the configure temperayure set up it will trigger to stop your compressor motor as well as the blower fan,blower fan independenly to you compressor.if your thingking that your compressor is tripping off,check your operating current on one line using clamp ammeter and compare to the rated current that tag on
motor compressor body,if the current flow is higher than the rated current specified on compressor motor,well problem occured it will trip your compressor,because overload protector is becoming your thermostat.but if you got same current result it was cycling process.If tripping off maybe air is present in your system call qualified ac tech, to purge out air in system.
SOURCE: DeLonghi Planus quick connect split heat pump.
I was told by a delonghi technician that it does this to defrost the unit.
Hope this helps.
SOURCE: My refrigerator (RB1855) runs excessively long.
There are about four different versions of your model. If you like I will send you the manual and we will work together as this refrigerator is very complex. Let me know, Thanks, Sea Breeze
SOURCE: model#asu9cq error code
need model and make, and serial if you have it, its an error code, but without make, cant tell u!
SOURCE: Compressor appears to kick in, runs for short time
It sounds like your unit may have a bad run capacitor or start capacitor and relay. Low voltage will also cause this problem. First you need to make sure that you have the full rated voltages at the unit, if you do, then, have the run and start capacitors checked out and the start relay.
