Unless you have an outlet for a cheap to free used screen element, scrap it and buy a new tv. These units range near 200 for rebuilt. That is plus your time and if you don't break it.
You can get a refurbished one on Amazon for $170:
https://www.amazon.com/Element-ELEFW408R-1080p-Certified-Refurbished/dp/B01MXE2U6D/ref=asc_df_B01MXE2U6D/?tag=hyprod-20&linkCode=df0&hvadid=312112258254&hvpos=1o2&hvnetw=g&hvrand=14853981044476798230&hvpone=&hvptwo=&hvqmt=&hvdev=m&hvdvcmdl=&hvlocint=&hvlocphy=1014106&hvtargid=pla-760644738912&psc=1&tag=&ref=&adgrpid=57636291490&hvpone=&hvptwo=&hvadid=312112258254&hvpos=1o2&hvnetw=g&hvrand=14853981044476798230&hvqmt=&hvdev=m&hvdvcmdl=&hvlocint=&hvlocphy=1014106&hvtargid=pla-760644738912
SOURCE: i have a samsung plasma
same price or even more the inside screen is the most expensive part and when you add the labor it is vary expensive. You also do not know if the cicuit boards are cracked or not and may have other problems in the future.
SOURCE: Oven door outer glass shattered
will need a model number to tell you the correct price ... most will have to replace the door... you can also give sears a call .. if you gripe loud ... they may replace it for you...
SOURCE: Our 32" flat screen Element
Panel screen is broken, need be replace. Price is too high ( new). Maybe is not worth repair.
SOURCE: have a lcd42f1080p tv have marks coming on the inside of the outer screen,can you advise please.
The set uses a display panel and IF the glass is not bonded to it but apart the only way to get to that area is dismantle the set and REMOVE THE ENTIRE DISPLAY UNIT (CALLED A DISPLAY PANEL) to clean whatever is in there out. Sometimes moisture condenses and gets on the inside of the outer screen.
If a shop looks or you call the maker they will know if that is possible or not and ITS NOT A DO IT YOURSELF JOB.
SOURCE: Remote control for a element elefw408 model 40
Check the remote control for its infrared emission. Check it with fresh batteries. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
