To get your LF2612D 26" LED TV combo out of home and retail mode, you can try the following steps:
Press the "Menu" button on your remote control to access the TV's settings menu.
Use the arrow keys on your remote control to navigate to the "Setup" or "Installation" option.
Look for an option called "Home/Shop Mode" or "Retail Mode". If you find this option, select it.
Change the setting from "Shop" or "Retail" mode to "Home" mode.
If you cannot find this option, try resetting your TV to factory settings. This can be done through the TV's settings menu or by pressing and holding the power button on the TV for 10 seconds.
If the issue persists, refer to the TV's user manual or contact the manufacturer's customer support for further assistance.
Press menu on your Emerson tv,scroll down to features, look for location,press location and under retail you'll see home. You should be back to normal then :)
Hi ekirchman
So that i can help you;
Could i have your tv`s model# so that i can give you the information that is pertinent to your model.
Be waiting for your reply
Question
What should I do if my TV is stuck in Retail mode?
Answer
Your TV may have been set to Retail Store mode, which is mainly used on the shop floor. For home use, we recommend that you set the TV to HOME mode, which will allow you to change the settings. To change to HOME mode follow the steps below.
Press the 'MENU' button on the remote control to access the main menu.
Move the cursor down to select INSTALLATION and move the cursor right.
Move the cursor down to select PREFERENCES and move the cursor right.
Select LOCATION and move the cursor right.
Move the cursor up/down to select HOME and press the 'OK' button for confirmation.
You need to go to service mode. Here how you go - use Samsung remote off the TV then press Mute-1-8-2-Power. Tv then boost up the service mode which is you could fine the line - user reset or hotel mode or both. You can press the user reset. If there is hotel mode - check it and put it OFF. Good luck
