If you are unable to install the driver software check if there are any driver files that have not been removed from your computer (this might have been installed during the incomplete installation). Also, check if you are installing the correct driver and if you have selected the correct operating system.
Open Change device Installation, and then select the Change device installation settings Control Panel setting. In the Device Installation Settings window, select the option to automatically download the driver.
Get ready for driver installation by connecting your printer to the computer with a USB cable or through your local network. Open Devices and Printers and select your printer's name, if it is not listed, then add your printer to the list.
You can also download the driver software from our website. Double-click the downloaded driver file, click Run and the installation will begin. Follow the on-screen prompts to complete the installation.
The driver software can also be installed from the driver CD. Load the CD in the drive and begin the installation. You can choose between Custom install and Easy install. It always better to install all the features.
Follow the on-screen instructions and install the driver. Check if you can Print a document after the installation. If you are unable to Print, then follow the troubleshooting procedure or call our tech support for assistance. Guideline to install the HP Printer Drivers visit
https://goo.gl/wPGPzp
install card in first
dont let windows do anything to try and install
run driver from nvidia
if windows still trys to override then download the driver and try everything offline
if none of that helps and windows overwrite the nvidia driver then you want to go into device manager and roll back driver to the nvidia one
install chipset driver 1st then install then install graphics
driver then install audio driver then other driver
or
install the chipset driver 1st then install other driver using device manager
Hi, You need to install the chipset drivers before it will take the audio driver. Go here to Acer support, download and install the chipset driver, then you can install the audio driver >>>>>>>
HAVE YOU UN-INSTALLED THE PREVIOUS SOUND DRIVER BEFORE YOU TRYING TO INSTALL THIS ONE? IF NOT, AND YOU ALREADY HAVE A SOUND DRIVER INSTALLED, YOU WILL HAVE TO UN-INSTALL IT OR DISABLE IT UNTIL YOU GET THE NEW ONE INSTALLED. THEN SET THE NEW DRIVER AS YOUR DEFAULT DRIVER ONCE INSTALLATION IS COMPLETE.
u should always turn off automatic updates.......and install drivers it will be work fine.. I will give u all drivers link....go to hp.com and search it.. for modem -sp33442, for audio-sp35270, for sm bus controller-sp36492, for quick lounch sp38171, for UAA sp32395, for webcam sp37849, download all drivers and install it.
and install drivers follow these steps:
Open device manager and right-click on Audio device on High definition Audio Bus. Select Install from a list of specific location (Advanced) Click Next Select Don’t Search. I will choose the driver to install. Select Sound, Game & video controller from the list of Hardware type Click on Have Disk Click on Browse and navigate to C:swsetupsp35270 and click on .ini file OK Click Next It will give you an update driver warning message. Click on yes. It will start installing the driver Click on Finish..
have installed XP in Compaq Presario 707TU Laptop. I have configured audio as below. Install Microsoft UAA sp31994, then install High-definition audio driver sp33443. But I get the error message "Driver Installation Failed: Could not find the MEDIA device for this driver."...
