Do you have the time adjustment set to Caller ID? If so, the time is being reset when your phone connects to the telephone company computer. To set this see the Advanced Setup options. Make sure that the phone system is in standby when you press the Menu/OK button to access the menu system. See page 17 of the manual for the information on the Advanced Setup options. The manual is available here: https://uniden.com.au/wp-content/uploads/2017/07/SSE_47_OM.pdf .
I hope this helps. My guess is your telephone provider either hasn't updated their clocks or otherwise is giving faulty time information.
The Uniden XDECT 8315 does not have an answering machine. It will check your voice mail. Setting that greeting depends on your telephone service provider. Check your provider's voice mail FAQ.
To have your XDECT 8315 get your voive mail messages, press Message and then select Voice Mail. Then follow the prompts to enter your voice mail access number. Alternatively, you can press Menu > Global Menu Settings > Edit Voice Mail. See pages 17 and 32 of the manual. (See the link below.)
If you do not have voice mail from your telephone company, you can add a stand-alone answering machine. Just make sure to connect the answering machine to the telephone jack. Then connect the answering machine RJ-11 out to the telephone's RJ-11 jack on the base.
From the handset, press Select/Menu and then press the down arrow to get to Ans Setup. Press Select again. Go down to Ring Time. Then select the number of rings (6, 9, 12 or Toll Saver (TS)). Press Select then press Flash/Exit to exit the menu system. Toll Saver picks up after 2 rings if you have new messages or 4 rings if you don't. This lets you hang up before the answering system picks up if you are using the remote phone access feature.
Note: if you have Voice Mail from your telephone provider, you need to set that to a longer number of rings separately. Consult with your phone company on that option.
Hope this is solved for you. If not, I found the connection for the battery a little temperamental and had to play with it a bit before the connection worked properly
you have to do it from the hand set, go into menu, using the arrows scroll down to date and time , use the arrows to select date , then hit select do the same for the time, then when the am option flashes use arrows then select , then its done , hope this helps
The manual does not make it clear that you have to set the day/date/time option on the handpiece - not on the base unit (which you would think was the logical place).
The base unit has only three options under its menu (see page 9 of the Owner's Manual).
