SOURCE: Both forward and reverse speed are decreasing
Hi, check the main drive belt, the belt is stretched out. you need too replace the main drive belt.
If this doesn’t work for you, please write back. Thanks,
SOURCE: shuts down in reverse
I'm not familiar with that particular mower but I'd bet it is a direct switch. Follow the shifter arm down and you should see a arm or button that arm contacts a switch when you put it in reverse. pull the two wires off that switch, put a wire in between to connect them and it is by-passed.
Please rate if this helps-
SOURCE: Loss on drive on Poulan Lawn Tractor
Check to make sure the belt is not broken or did not come off the transaxle pulley, you can check by removing battery from under seat and pulling battery box out to examine top of transaxle,Pay close attention to the wire belt guide on the rh side of the transaxle pulley it should be close to the backside of the belt after it is reinstalled.If you recently may have removed the rear tire make sure the square key on the axle didn't drop out.Is the tractor a hydrostat drive? If so make sure brake is not stuck on,if it was it would make a grinding noise.
SOURCE: Craftsman 13 hp lawn tractor slipping in reverse and low gears
Really hard to say without looking at it but it sounds like a pully has seperated or is trying to come apart they are made in two peaces.
SOURCE: why does my lawn tractor tractor rev way up when
that could be caused by a sticky float valve--remove the bottom of the carb and make sure the float valve moves up and down very freely
