Marquis Hideaway Retreat 110v hot tub.
SOURCE: JACUZZI HOT TUB J365
MOTOR TO HOT TUB KICKS OFF ON HIGH SPEED AND GETS VERY HOT AFTER RUNNING ABOUT 20MINUTES AND STARTS BACK UP IN LESS THAN A MINUTE,BUT CONTINUES TO KICK OUT ,IVE REPLACED THE MOTOR AND STILL SAME PROBLEM..
SOURCE: Motor is hooked up correctly according to
You have 220v running into your motor, the red and the plack are in most cases the same 110v line and what your calling a white netural is a common line. In other words the second half of your 220v line. If your red and black are the two opposing 110v lines that make up your 220v and they are put on the motor and turned on they short aginst each other and blow the breaker. One of your 220v lines should come into your hi -low switch and then split to your high and low on the pump. The other half of your 220v line will go to the common or what your calling nuteral. The difference is a netural completes a 110v circut and a common completes the 220v circut it will take to run the motor. One of the splits will complete the low speed circut and the other will complete the high speed circut. You need to check your voltage comming into the spa, the way the spa is wired (110v-220v), and how the motor is wired (110v-220v). For your spa this will be in your owners manuel or on a scematic inside a panel or door and is quite often a plug you change from one spot to another. On your motor will have a scematic on the back of the motor that will tell you haw to adjust the wireing already in place on the wire board of the motor. This may sound deep but if all your voltages are set the same and your high and low are the same leg of power, this should fix your problem.
make sure you make a wiring diagram or just unplug the plug from the mother board and search your area for your local pool pump repair guy with free testing. these are a high $$$ motor and not a good one to practice on, save it for a pro ! it might just be a dirty switch or need to be reset I don't charge any thing for that, and while your there ask him how to take better care of your $$$ pump ?
jay the pool pump repair guy longwood Florida
There are several things that can cause this symptom. If you have a volt/ohm meter and call the Hayward technical support at 908-355-7995
they might be able to help you figure this issue out. I hope this helps.
Please vote on this answer. Thank you.
