KX-TGA402C is the included handset for a Panasonic cordless phone system like the KX-TG4011C. You should be able to adjust the ringer volume from the Initial Settings menu. With the phone system in standby, press Menu on one handset. Use the Up/Down arrows to locate the Initial Settings. Press OK. Then select Ringer settings and press OK. Select Ringer Volume and press OK. Use the Up/Down arrows to set the desired Ringer volume and press OK to save. Press Exit to leave the menu system. Alternatively, you can adjust the ringer volume by pressing the Volume Up/Down buttons while the phone is ringing.
The manual for the KX-TG4011 is available from Panasonic here: ftp://ftp.panasonic.com/telephone/om/kx-tg4011_mul_om.pdf . If the above steps aren't working, check that your handset and phone base are properly paired (registered handset). Also check that the base has power and connected to a working phone line. Also make sure that the handset is fully charged.
I hope this helps.
SOURCE: phone ringer
You can download the manual for a very similar phone, the KX-TG2302 at http://service.us.panasonic.com/OperMan/findmanual.aspx?cat=TEL and you can figure out all the features of a KX-TG2303. The simple answer is: while you are not using the phone, press the up or down volume button and it should turn the ringer back on. To turn the ringer back off, press and hold the down volume button until you hear two beeps. You can adjust the volume while the phone is ringing. The manual will tell you how to change your ringer tones, etc.
SOURCE: ringer
1. Press Menu button
2. Press multibutton "down" repeatedly to display "settings BS", then press multibutton "right" {>}
3. Press {2} two times
4. Select the desired setting by pressing {1} for low, {2} for medium, {3} for high or {0} for off.
5. Press multibutton {>}, then press on/off button
Thats it....
Have fun
SOURCE: Panasonic cordless phone,
press menu,scroll down to ringer settings,hit select,scroll to ringer volume and hit select then press up the round button in the middle until you hear it make a "ring" sound. adjust your preferred volume and hit save.
SOURCE: my vtech cordless phone will not ring. message is ringer off. how to turn ringer on.
Does your handset have a PROG button? Press that, then press the VOL+ button until you come to RINGER VOL: OFF. Press SELECT button, then use the ^ (VOL+) key until you get the desired volume level. Press SELECT again, then OFF. You're good to go.
SOURCE: My Panasonic kx tg-2620 shows "ringer off". How do I turn it on?
To solve it, I pressed Menu then the silver down arrow to access the Ringer Settings. For some reason, I was trying to use the black buttons beside the Menu button to navigate.
Thanks anyway!
