Question about Measuring Tools & Sensors
Valve clearance on intek 20HP v twin
Cancel
SOURCE:
  • 95 Answers
SOURCE: Looking for Intake + Exhaust valve clearances for
The cold setting is .002 for the intake and .004 for the exhaust.I just set them both at .003 and it works fine.
Posted on Aug 09, 2009
  • 8 Answers
SOURCE: I have a Briggs 18.0 Intek - seems to be locking up when crankin
set the intake at .003 to.005 and the ext. at .005 to .007
Posted on Sep 13, 2009
FlyingLabRat
  • 468 Answers
SOURCE: B&S Intek 20HP, first minor ticking, then . . .
you can replace the valves without removing the engine by removing the head first. The valves will come with it, however, the mechanical clunk isn't usually indicative of valve issues. I would remove the head, and push on the piston to see if you threw a rod instead. Sounds like the connecting rod was knocking, then gave way, and now the piston isn't moving at all. Another way to tell, is just to put a screwdriver in the spark plug hole, and turn the engine over by hand and see if the screwdriver moves. If not, you need to tear the engine down and fix your rod issue. If you're lucky, you may find the the end cap bolts came loose, and you can put it back together without too much issue. Otherwise, your engine's probably done.
Posted on Feb 01, 2010
  • 10 Answers
SOURCE: we have 42'' Yard Man riding lawn mower need to how to change oil
it's a square head pipe plug @ base of eng. either right or left side of machine may also have a quik change fitting instead its black plastic w/ yellow cap
Posted on Apr 12, 2010
Testimonial: "Thanks for the info, you where right on the money.. I finally found it, its on the right side if you were sitting on mower. Thanks again!"
kel1guy2002
  • 3740 Answers
SOURCE: After reading similar problems, I
Hi and welcome to FixYa. I am Kelly. Down load the manual below and first see page 104. Then go to page 24 for the adjustment procedure.
Posted on Oct 18, 2010
What are the valve clearence settings for intake and exhaust on 20hp b/s #461707
.004"-.006" on intake and exhaust valves cold engine. I would set them at .005" .
Feb 16, 2017 | Briggs & Stratton Briggs Stratton Intek V...
How do I adjust the valves on a Briggs and Stratton Intek V Twin
Remove the valve covers look up your valve clearance specs turn the engine by hand until the piston is at top dead center then go 1/4 turn past that and then put a feeler gage for the valve clearance you need for that valve and snug up the adjustment nut. Check your oil when your done some oil will spill out when opening the valve cover.
Apr 17, 2013 | Briggs & Stratton Briggs Stratton Intek V...
Briggs 20HP Intek sputters under load
reset the valves to specifications by gaping them all to .008 thousands The vibration will continuely make the gap wider causing this problem to get worst. Gap the valves is recommeded every other year
Jun 14, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Have a 20hp vanguard on a go-devil long tail motor. engin runs at idle speed then when i put the propeller into the water it stalls. if i pull the choke and give full throttle it will run some and backfire
These engines seem to have problems maintaining the correct valve lash settings. try taking the valve covers off and checking the valve/pushrod clearance.on tdc compression stroke it should be .001-.003 clearance. then check exhaust stroke tdc on exhaust stroke. clearance should be same on the other valve then. hope this cures your problem.
Dec 22, 2009 | Briggs & Stratton Briggs Stratton Intek V...
B&S Intek 20HP, first minor ticking, then rough running (like missing one cylinder), then mechanical clunk . . . now zero compression! What should I look at first? Can valves and valve gear be replaced...
Sep 27, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Measuring Tools & Sensors Logo
65 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
