Question about Refrigerators
My frig is making a hising sound why - Refrigerators
    Master:
  • 665 Answers
Refrigerant might be leaking out.
Call the Maytag Repairman!
Posted on Apr 22, 2019
SOURCE:
Step on brake air hising sound an brakepad goes down.
You have a defective power brake vacuum booster diagram. It is the large round thing under the hood that the brake master cylinder is bolted to.
Oct 29, 2016 | Cars & Trucks
Brake hising
It appears that you have a broken brake booster diaphram or seal Suggest you replace booster with a new item or one from the wreckers
Jan 28, 2013 | Cars & Trucks
2008 Sportster 1200C - When I turn the engine off it makes a hising sound - like air escaping. Also, when hot, there is a hesitation between pushing the starter button and the engine turning over. Almost...
The hissing sound that you're hearing may be crankcase pressure being bled off or compression bleeding off through a valve that is not completely closed. The delay on the engine turning over could be caused by residual compression, a slow starter relay, or a slow starter solenoid. How old is the battery. Heat, vibration, and age is what kills a battery, not mileage.
Good Luck
Steve
Jun 28, 2011 | 2006 Harley Davidson XL 1200 C Sportster...
Control settings will not change so the blower fan does not push any heat or defrost.
It sounds like the blend door is not switching. Many times a broken vacum hose under neath the hood will cause this. The blend door is vacum operated, if one of the hoses is cracked you wont have a functioning blend door. Usually with the vehicle running and hood open you may hear a hising noise. Locate it and fix it.
Dec 01, 2010 | 2002 Chevrolet Blazer
My frig makes a humming sound off and on. I can
It appears that the balance of the machine is not correct. Please try to adjust the level by adjusting the adjustable wheels at the bottom. If it does not stop Please remove the back panel and when it starts humming observe which of the part is viberating or making noise. If loose tighten it or fix it. It is not a major problem and has nothing to do with the performance of frig
Jan 22, 2010 | Maytag MSD2655HE Side by Side Refrigerator
Lights out..White box is clicking in back base of frig
sounds like the relay box on compressor . . you can repl the relay . it's not a hard job .. and its lso a very common problem on many frig's . ****
Jan 04, 2010 | Refrigerators
Unit stopped running. T-stat just makes a clicking sound
Are you sure its the thermostat that is clicking and not the compressor. IF the click is comming from inside the frig it is the thermostat, but if its comming from the rear of the frig its the compressor.
If its the thermostat thats clicking you can unplug the frig and remove the thermostat and jump the two wires together and plug the frig back in to see of the compressor comes on. If it comes on, replace the thermostat.
If it doesn't come on check to see if you have current to the compressor. If no power to the compressor check to see of the frig is stuck in defrost. Locate the defrost timer and advance one click and observe if the frig comes on. If the frig comes on at this point replace the defrost timer.
Dec 29, 2009 | Refrigerators
Side by side makes a whistling sound--Model RS2630
I have the same frig-- The sound is coming from the litttle fan behind the frid. Take the bottom silver cover off and you will see the fan in a plactic white frame thing. Unplug it and then put a little oil inside the fan motor-- (oil based solvent). You may have to take it out of the plastic frame. To get the oil into the motor really good. Just use some 3 in 1 oil or wd-40. You will probably have to repeat this every couple of months. But it gets rid of that awful nosie. I also found that if you give the frig more air to circulate than the oil will last longer. Meaning don't put the frig so close to the wall. Oh please remember to unplug the frig first. I hope this helps.
Dec 29, 2008 | Samsung RS2630SH Side by Side Refrigerator
Syvania 32 in. srt2232x
Sounds bad im afraid. If its worth it your best to take to a repair shop. If not it might be a gonner
Aug 03, 2007 | Sylvania 6413TC 13" TV
Refrigerators Logo
Top Refrigerators Experts
Marvin
Marvin
Gil Shultz
