SOURCE: johnson 4 stroke 115 hp will not start. fuel
Sounds like and injector problem to me. If it was a 2 stroke I'd tell you to pull the carbs and clean them ,but EFI is a whole different story. Most certaintly a fuel problem, most likely injector related, you'll most likely need to go see a marine mechanic with the proper equipment to analyze, rather than start replacing parts you may not need.
SOURCE: Trying to find out correct year of manufacture for
All of the engine model numbers will look like this:
115MLCI
115
1981
115MLCN
115
1982
115MLCO
115
1985
115MLCR
115
1984
115MLCS
115
1980
115MLCT
115
1983
115MLES
115
1990
115TLCI-115TXCI
115
1981
115TLCN-115TXCN
115
1982
115TLCO
115
1985
115TLCR-115TXCR
115
1984
115TLCS-115TXCS
115
1980
115TLCT-115TXCT
115
1983
115TLES-115TXES
115
1990
It should be on the port side of the transom bracket(On the engine to boat mounting bracket). If not, look around on the engine block for a small silver plug (It will look like a shiny freeze plug) There will be 2 sets of numbers... one of the above numbers and your serial number will be the second number.
SOURCE: 93" 115 H V4 Johnson outboard motor will start and idle fine
your carburetors might be dirty blocking flow to the high speed jets causing it to bog down
drive shaft oil seal and possible shaft
take it to an outboard service shop as it may require special tools for the job
