Depends on when it was built for location Vehicles Built After 03/2002 it is behind the radio. Vehicles Built Before 03/2002 it is under the passenger side of the dash behind the pcm. time depends on location and your skill level [easiest location less than 1 hr ] and yes to programming this company --ford dealer --or an auto repair shop in your area can give you estimates https://moduleexperts.com/gem-modules/?gclid=Cj0KCQjw3f6HBhDHARIsAD_i3D8dSWrY2Pb-BieP04uo_k1ym67nXPQP5BwEJfVhhlYwCNg2AA4OxJ4aAiq9EALw_wcB
Your vehicle does not have a GEM ,uses vehicle security module and it is located behind the right rear trim panel .
SOURCE: GEM module replacement
try a salvage yard that has an expedition or an f150 pickup and take the parts off and install in yours disconnect the negative side of the battery and you shouldn't have to have it reprogrammed
SOURCE: How do you access the spark plugs 2002 mercury mountaineer
IIRC these are a coil over design. meaning the coil is over the plug. the coil should have one 8mm bolt holding it on the lower intake manifold. remove the coild to get to the spark plugs. look by the fuel injectors, coil should be just next to it or very close. coil usually says motorcraft on it and circle in design.
good luck
Michael
ASE certified
SOURCE: 2002 mercury mountaineer 4.0 starter relay location
The power distribution box is
located in the engine compartment.
The power distribution box contains
high-current fuses that protect your
vehicle’s main electrical systems
from overloads.
The starter relay is in position #56 of that box.
SOURCE: Location of GEM Module on 1998 Ranger
i am almost sure it is in steering col area by firewall. but call any part store like auto zone and they can print it out and tell you if your ford dealer wont. but on the fords they usualy are all in the drivers steering area sometimes way up by fire wall
SOURCE: cabin filter location mercury mountaineer
There is one for the 2003 Mercury Mountaineer. If you are smellign a "vinegar" odor, mix a solution of 1 part bleach to 3 parts water and pour it down the grid at the base of the windshield. It will take care of the smell.
