Question about Home
We bought a uberhaus dual flush toilet and when we flush it the water comes out of the top of fill valve. What is a fix for it? Does it maybe need cleaned?
    Top Expert:
  • Home Master
  • 52,423 Answers
Replace the valve
Posted on Apr 23, 2019
SOURCE:
picatudo
  • 239 Answers
SOURCE: Toilet fills up slowly
buy a universal fill valve and replace it
Posted on Jan 03, 2009
SOURCE: Toilet Refills Every 15-Minutes
I have minute amount of leakage into the bowl causing mold to grow. I believe that it may be the rubber seal for the flapper body to the porcelain.
Posted on Jan 10, 2009
  • 6 Answers
SOURCE: Toilet will not fill up
Some Toto fill valves have a plastic debris screen located at the inlet connection. Turn off the supply valve and remove the supply connection at the bottom of the tank. Use a mirror to inspect the screen for debris.
I agree w/ Smithbrother, the Fluidmaster fill valves are cheap and work well. The only thing they ever need is an occasional seal for $1.50 and 5 minutes to replace.
Posted on Mar 14, 2009
bearsfan7538
  • 119 Answers
SOURCE: I have 2 K3466 model Kohler toilets and just had a
There is a volume control screw on the valves usually a plastic thumbscrew on side of valve turn clockwise until they quiet up the plumber should have adjusted that these are very tempermental toilets but when adjusted properly are excellent toilets I have 2 in my own home
Posted on Nov 15, 2009
SOURCE: toto toilet with gmax flushing system blue top
I have the same problem and can not find a solution. The toilet flushes fine but then a delay in filling up the tank occurs. Is there a part I can replace? Does something need to be cleaned or cleared?
Posted on Jan 15, 2010
I have a uberhaus dual flush toilet. I turned off the water supply in the house to work on a sink and when I turned it back on the toilet won't fill anymore. If I fill the tank or the bowl it will flush...
You will have to disassemble the fill valve and clean it. When you shut the water off and on to work on the sink it dislodged dirt and scale in the water piping which clogged the toilet fill valve. Check your lavatory sink areators too they may also be partially plugged. Hope this helps.
Bob
Jun 09, 2014 | Home
Why my uberhaus dual flush toilet does not flush properly
Perhaps it is taking a long time to fill the cistern, take top off and see if it's filling after flushing, if it's slow and pressure is ok it is likely to need a new diaphragm in the filling valve.
May 12, 2014 | Home
The toilet isnt flushing and water is not filling into the cistern? (at the top) how do i fix this problem??
If I understand correctly, the tank that holds water is not filling up with water.
1) If this is the problem, then you need new toilet fill valve.
Or clean sediment out of existing fill valve by removing and soaking in CLR calcium rust lime.
To replace fill valve:
Look at water supply line coming into tank.
Supply line connects to fill valve.
Buy new fill valve at home center, hardware store, or walmart, or online.
There are two nuts connected to valve. Each nut has companion rubber washer
One nut & washer seal water supply line to tank.
Second nut & washer seal valve to tank.
2) If water tank is full of water, but water does not flow rapidly into bowl when you push flush lever, then your toilet is clogged with sediment.
To solve sediment problem when flush water will not flow rapidly into tank, then buy CLR calcium lime rust.
Pour CLR down into overflow tube located inside water tank.
Make a funnel by cutting off bottom of water bottle, or cut paper cup into a funnel.
Pour cup-full after cup-full of CLR into overflow tube until sediment and CLR are coming out all flush holes located under-rim on bowl.
3) Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 22, 2011 | Home
Water runs after it fills up?
I am not familiar with that model, but it sounds like your fill valve is leaking or the water level in the tank is too high. Take the toilet tank top off and flush the toilet. When the water gets full and you hear the water stop ( except for your leak) look at the flush valve. Is water running over the top of it and running into the hole in the middle? Then the float need adjustment.
If you are hearing you leak still, lift up on the float. Did it stop? if so the valve may need adjustment due to it not seating completely. You can probably find something online (youtube) easier than I can explain it.
Sep 08, 2010 | Caroma 270W-RF Reflection Round Front...
I have a Jacuzzi Perfecta toilet (bought Aug. 21, 2008) at Lowe's. I have the sales ticket. The toilet works fine. The tank fills very slowly (2 minutes) before it shuts off. It also makes a whistling...
Have you tried shutting water off and take top of valve appart and flush it out. It may have something in valve causing water to be restricted. It will have an arrow on it to direction to get it to come off.
Take appart and clean rubber disc and you can put something over top of valve , a small cup or something to enable you to flush the tank. Have someone help you and hold the cup above the valve so that when you turn water on for a few bursts to flush out the valve it goes into tank.
The actual stream that flows through valve is restricted down to almost 1/8 " opening so it wouldn't take mush to block the flow of water.
The disc you take out you can replace it, if it seems to be damaged and not working correctly. That will affect the flow also.
Jun 10, 2010 | Jacuzzi Bath Perfecta EZ33 959 White round...
Water fills tank slowly
Check your angle stop ==valve underneath close to the wall see if it's open all the way if it is and you still have the same problem then go ahead and shut it off, disconnect it from the toilet and the valve and see if there is anything stuck in the hose (a gasket maybe) if nothing blocks the hose then. Reconnect the hose starting from the valve put a bucket on the other side to catch the water and open the valve as if to clean the hose. After you do that reconnect the hose and try again if still does not work properly then you have to replace the fill valve (the tower looking stuff inside the tank)
if it works for you, don't forget to rate me
thx
May 27, 2010 | Caroma CARAVELLE270ADAW-EL Caravelle...
Hello, we have a dual flush toto and since installation we've had a problem with the water filling up after a flush. every single time i have to take the cover off and twist the flush valve (the part on...
check the water supply tube.remove and check to see if any blockage is present.either remove completely and blow through it,or just remove top of tube and inspect it.this has happened to me various time's.possible solution.
Apr 16, 2010 | Toto Aquia II Dual Flush Toilet
Toto CST853 cistern will not refill. Was fine yesterday. City is working on pipes and broke a water main last evening, all other faucets and toilets are working....can I clean the water filter or does it...
alot of times you can turn the water off to the toilet and the tops of the fill valves usually pop or screw off. then if you put a small cup over the top of the fill valve you can turn it back on and flush the debris out and put it back together. if its a fluid master type you can pop the top off it. and turn the float arm a 1/4 to half turn and the whole top will come off
Jul 31, 2009 | Toto Aquia II Dual Flush Toilet
Kohler one-piece has no flushing power
Hi
try to increase the amount of water for each flush .
Jul 17, 2009 | Kohler Toilet - One Piece with Ingenium...
New Pegasus Dual Flush Toilet Water does not enter Toilet bowl
There is a small plastic tube that comes from the fill valve and attaches onto the overflow tube on the flush valve. If no water is coming out of that tube, then it is clogged internally. You can remove the tube from the fill valve and take a small piece of wire or a straight pin to try and clear it from the outside. If that doesn't work, then I would recommend replacing the fill valve. They are inexpensive to replace. If you don't know how to get into the fill valve's internal guts at the top, then I would recommend replacement of the valve. One more thing, there also could be a water saver where the outlet is on the little tube I just explained. It is usually light blue, you can remove that and discard it.
Mar 21, 2009 | Pegasus Technologies Pegasus Toilet Paper...
Home Logo
Top Home Experts
Donni Steen
john h
Are you a Home Expert? Answer questions, earn points and help others
