Question about Exercise & Fitness
I have a Fibit Zip. The dashboard shows two conflicting number of steps for this week's report and last week's report.
Causes what are the main sources of conflict?
I would say religion is number 1 and disputes over borders is number 2, and the people versus dictators is 3..
  • UNDERSTANDING CONFLICT - University of Hawaii System https://www.hawaii.edu/powerkills/WPP.CHAP16.HTM UNDERSTANDING CONFLICT AND WAR ... world opinion. War is a particular type of ... Appendix 16C provides methodological detail and the sources for evaluating the ...
  • Major Causes of Conflict ' Chron.com smallbusiness.chron.com > Human Resources > Causes of Conflict Skip to main content. ... Major Causes of Conflict by George N. Root III, Demand Media . ... Mediate: What Are the Sources of Workplace Conflict?
  • Sources of Conflict in the 21st Century: Regional Futures ... www.rand.org > Published Research > Monograph Reports This book examines current political trends and potential sources of conflict ... Sources of Conflict in the 21st Century. ... RAND monograph/reports presented major ...
  • List of ongoing armed conflicts - Wikipedia, the free ... https://en.wikipedia.org/wiki/List_of_ongoing_armed_conflicts The following is a list of ongoing armed conflicts that are taking place around the world and ... where the main takes ... Ongoing conflicts in World :
  • Jul 01, 2016 | Computers & Internet
    How to retrieve 1 week ago fax history from brother 2280 fax machine
    Printing reports
    How to print a report
    1 Press Reports.
    2 Press ? or ? to select the report you want.
    Press Menu/Set.
    -OR-
    Enter the number of the report you want to print.
    For example, press 2 to print the Help List.
    Following reports are available
    1.Transmission
    Prints a Transmission Verification Report for your last transmission.
    2.Help List
    Prints the Help List so you can see at-a-glance how to quickly program your machine.
    3.Quick-Dial
    Lists names and numbers stored in the One-Touch and Speed-Dial memory, in numerical order.
    4.Fax Journal
    Lists information about the last incoming and outgoing faxes. (TX means Transmit.) (RX means Receive.)
    5.User Settings
    Lists your settings.
    6.Network Config (MFC-7225N only)
    Lists your Network settings.
    Jun 11, 2011 | Office Equipment & Supplies
    Hi, the following started to happen: 1. Our wireless Internet recently started to develop problems. The signal drops and using the "View wireless network', our secured home network will not show...
    It sounds like you have a problem with a conflicting Wireless signal in your area.
    This is caused by another wireless network close by that is on the same channel (or within 5 channels higher or lower) than yours that is causing interference.
    You can check this by performing the following:
    1. check your wireless network at the moment and see if you can see what the channel number is that is being used at the moment, make a note of this.
    2. switch your router off (making sure that any settings that you may have changed on the router have been saved first!).
    3. browse for any wireless networks that are in the area, and make a note of the channel numbers that these wireless networks are on. You should find that there is another network on the same, or close to the same, channel number that your wireless network is on.
    4. power on your wireless router.
    5. whilst the router is coming back on, take a look at the networks that you have found and see if there is a channel that is available that is 5 different from everyone else (ie, if there is a network on channel 1, you will be looking to use channel 6, if there is one on 7 use channel 2, etc). If there is no completely clear channel you may need to try and just look at the strongest signals for a 'free' channel.
    6. once your wireless router is back up, log on to the configuration page (may be best to use a wired connection if possible, to avoid disconnections mid-configuration)
    7. find the wireless configuration page, and set the channel number to the one worked out in step 5
    8. retry the wireless network and see if you get better performance and a more stable connection
    Wireless networks are a bit picky when it comes to interference, and they ideally need 5 channels of separation, otherwise the carrier signals can interfere with each other. But with not being able to control your neighbours networks, it can be difficult to get a completely clear channel :)
    The other thing to check for is if you have had a change around in the house, and perhaps bought a new appliance (such as baby monitor or cordless phones or a fish tank), as some items can throw out interference to conflict with wireless networks.
    Hope that this information is of some assistance to you!
    Nov 08, 2010 | D-Link RangeBooster G WBR-2310 Wireless...
    I just installed air conflicts and the windows error window pops up when i try to play it. whats wrong?
    It is possible to play Air Conflicts on Windows 7.
    First thing I would try is installing the version of DirectX that is on the Air Conflicts CD. If you insert the CD a panel should appear, click the Install DirectX button and follow the on-screen instructions.
    If that fails there is an update which sometimes solves this sort of issue for some video cards. Just click on the link below to download a zip file (it's under 200 KB).
    http://www.contactsales.co.uk/downloads/AirConflictsUpdate1_43.zip Download the zip file to your computer. Open the zip file and run the program, follow the instructions to complete the update. Try running Air Conflicts again.
    Regards
    Technical Support
    Dec 21, 2009 | Destineer Air Conflicts for Windows
    Can a sharp ux-p410 retrieve old sent faxes from its memory
    No, your fax machine only records the fax number of the last 50 transactions
    Oct 19, 2009 | Sharp Office Equipment & Supplies
    I faxed something last week and lost the transmisson verification report, can it be re-printed? does my fax keep it in memory?
    It's possible to print a Fax Activity report which would show both incoming and outgoing fax activity. To do this, do the following:
    1. Press Reports
    2. Use arrow keys < > to select 3. Fax Activity
    3. Press Set
    If Fax Activity hasn't been set up, do the following:
    Setting the Fax Activity Report Interval
    You can set the machine to print activity reports at specific intervals (EVERY 50 FAXES, 6, 12, 24 hours, 2 or 7 days). If you set the interval to OFF, you can print the report by following the Steps in the next page.
    1. Press Menu, 2, 4, 2.
    2. Press or to choose an interval,
      and then press Set.
      (If you choose 7 days, the LCD prompts you to choose a day at which to begin
      the 7-day countdown.)
    I hope this enables you to recover your transmission report. Please post back with any questions or just to rate the solution. Thank you very much.
    Greg
    Aug 11, 2009 | Brother IntelliFAX 4100 Laser Fax
    How can i generate incoming call report ?
    To print a report:
    1. Press the [Menu] button on the Control Panel, until Reports is displayed on the top line of the Display Screen. The Phone Book menu item will be displayed on the bottom line.
    2. Press the right or left arrow button to scroll until the report or list you want to print is displayed on the bottom line.
      • Phone Book: Phonebook list
      • Sent Report: Sent fax report
      • RCV Report: Received fax report
      • System Data: System data list
      • Scheduled Jobs: Scheduled job information
      • MSG Confirm: Message confirmation
      • Junk Fax List: Junk fax number list
    3. Press [Enter] to print the selected information.
    Your machine can print reports containing useful information. The following reports are available:
    • Phonebook List: This list shows all of the numbers currently stored in the machine's memory as Speed Dial and Group Dial numbers. You can print this phonebook list using the [Phonebook] button.
    • Sent Fax Repor: This report shows information of the faxes you recently sent.
    • Received Fax Report: This report shows information of the faxes you recently received.
    • System Data List: This list shows the status of the user-selectable options. You may print this list to confirm your changes after changing any settings.
    • Scheduled Job Information: This list shows the document currently stored for Delayed faxes or Toll Save faxes. The list shows the starting time and type of operation.
    • Message Confirmation: This report shows the fax number, the number of pages, the elapsed time of the job, the communication mode, and the communication results. You can set up your machine to automatically print the message confirmation report after each fax job.
    • Junk Fax Number List: This list shows up to 10 fax numbers specified as the junk fax numbers by using the Junk Fax Setup menu. When the Junk Fax Barrier feature is turned on, incoming faxes from those numbers will be blocked. This feature recognizes the last 6 digits of the fax number set as a remote fax machine’s ID.
    • Multi-Communication Report: This report is printed automatically after sending documents from more than one location.
    • Power Failure Report: This report is printed out automatically when power is restored after a power failure, if any data loss occurs due to the power failure.
    NOTE: The lists you have set to automatically print out will not print out when there is no paper loaded or a paper jam has occurred.
    Aug 04, 2009 | Xerox PE120i Laser Printer
    Activity Report
    The journals show the last 30-50 transactions, you might get lucky..
    Scroll through the menus for PRINT JOURNAL.
    Oct 29, 2008 | Canon LaserClass 2050 Plain Paper Fax
    WORKCENTRE PE220 - How do I print reports from the fax? and I want to set it up to do automatically, but I also need to look at a certain day, to see if a fax went through. Thanks
    Hope this helps.
    1. Press the [Menu] button on the Control Panel until 'Reports' is displayed on the top line of the Display Screen.
    2. Press the [Left] or [Right] arrow button until one of the following reports is displayed, and then press the [Enter] button to print the report.
    Report / List Description Phonebook List This list shows all of the numbers currently stored in the machine's memory as Speed Dial and Group Dial numbers.
    NOTE: This list can also be printed by pressing the Phonebook button on the Control Panel.
    Sent Fax Report This report shows information on recently sent faxes. System Data List This list shows the status of the user-selectable options. This list can be printed to confirm any modifications to settings that have been modified. Scheduled Job Information This list shows the documents currently stored for Delayed faxes. The list shows the starting time of the Delayed fax. Message Confirmation This report shows the fax number, the number of pages, the elapsed time of the job, the communication mode, and the communication results. You can set up your machine to automatically print the message confirmation report after each fax job. Junk Fax Number List This list shows up to 10 fax numbers specified as the junk fax numbers by using the Junk Fax Setup menu. When the Junk Fax Barrier feature is turned on, incoming faxes from those numbers will be blocked. This feature recognizes the last 6 digits of the fax number set as a remote fax machine’s ID. Multi-communication Report This report is automatically printed after sending documents from more than one location. Power Failure Report This report is automatically printed when power is restored after a power failure, if any data loss occurs due to the power failure. elem_1_spacer.gif
    Jul 23, 2008 | Xerox Office Equipment & Supplies
    Exercise & Fitness Logo
    19 people viewed this question
    Top Exercise & Fitness Experts
    Treadmill Repairs...
    Tom Chichester
    ray gallant
    ray gallant
    Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
