Question about Tissot Watches
Stop flashing Tissot Touch keeps on flashing. Haven't touched the watch for 10 minutes.
SOURCE:
SOURCE: "Tissot Touch" Touch screen failure
it all stems from the watch not actually being waterproof it's more water resistant than waterproof. The little indentations on the back that look like they are for a tool to unscrew it are actually holes i guess for the altimeter and meteo so it can sense pressure. Behind the back just behind the holes is a nylon gauze material and underneath this is a sensor slightly recessed and covered with some kind of waterproof substance. As far as i can see the problems lie here any water sweat or other foreign object than gets into this gauze will eventually will clog this gauze material which at first will affect the altimeter then the meteo. When the gauze has been clogged up severely i gets very dirty indeed which means when it gets wet it takes an age to dry out so if you wear it in the shower like i used to it will never dry out this causes the watch to malfunction quite severely. You can actually fix this problem yourself just get a very small flat screwdriver and lever the back off don't worry it's only a push fit and comes of easily you will see straight away a dirty damp smelly clogged up round piece of nylon gauze clean this up with a bit of WARM not boiling soapy water being careful not to disturb the pressure sensor and it's waterproof goo inside then dry it all and put it together
Hope this helps
Dom
England
Posted on Feb 26, 2008
SOURCE: Tissot T-Touch T33.7.788.51 Bracelet replacement
Sounds like it's broken @ a factory sealed link (non servicable). Local jeweller should be able to order & fit you a new one
Posted on Mar 28, 2008
escapement
  • 2338 Answers
SOURCE: bAtt flashing on digital screen although I only
Yes, the flashing battery icon tells you it's time to change the battery.
Despite of that the watches are fitted with brand new batteries when they are leaving manufacturer, there can be a significant period of time till they reach their new owners and the watch battery can be flat (or allmost flat) at the selling point.
I suggest you visit sellers shop again a.s.a.p. and ask for the brand new battery to be fitted under the warranty.
Rate me, please.
Posted on Mar 24, 2009
escapement
  • 2338 Answers
SOURCE: Wrong airpressure reading in my Tissot Touch
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all TISSOT watch manuals.Rate me, please
Posted on Mar 23, 2010
escapement
  • 2338 Answers
SOURCE: t-touch - Tissot is not synchronized
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all TISSOT watch manuals. Rate me, please..
Posted on Mar 31, 2010
After battery change (Tissot T-Touch watch) the display shows gibberish and the alarm sounds when not set. How to reset?
You can easily reset a Tissot T-Touch watch by following a few simple steps. Press the "T" button on the middle right side of the watch. Push the "Plus" button on the top right side of the watch to advance the minute hand to the correct time.
Aug 26, 2018 | The Watches
What are the quality and price of Tissot watches?
Tissot was established in 1853 in Le Locle, Switzerland. The brand has been an official timekeeper for a variety of sports like Ice Hockey, Cycling, basketball, and many others. The catchword of the company is more than a watch, Tissot, Innovators by Tradition, Swiss watches since 1853. This brand is largely targeted towards men. Tissot has awesome collection for both genders.
If you are searching for new technology then here it is. Tissot has brought out models which uses solar energy. Apart from this special feature the other features include t touch, compass, barometer, altimeter, etc. The collections from this brand are touch collection, T Classic, T-Sport, T Gold, etc.
The price from this collection in India ranges between 10 thousand and 1 lakh 50 thousand.
Buy Tissot Watches India Check Prices Features Models
Mar 04, 2016 | Tissot Watches
How do I reset my tissot t touch expert
Steps to Synchronize the Hands
  1. Press the centre pusher (T). The watch should beep once.
  2. Touch the centre of the touch-sensitive face until opt appears, in opt select 24H Cm (or 12H Fft or 24H Fft or 12H Cm) is shown in the digital LCD display.
  3. Press and hold the centre pusher (T) for approximately 5 seconds. The watch will beep once and then again, a second time, after 5 seconds have passed. After the second beep, the digital LCD display should read SYNCHRO. If not, return to step one.
  4. Press the upper pusher (+) to advance the hour hand until it is positioned exactly at 12:00. (PH press T button to to switch to minute hand adjust)
  5. Press the lower pusher (-) to advance the minute hand until it is also positioned exactly at 12:00.
  6. When both hands are aligned together and pointing directly at 12:00, press the centre pusher (T) to save the setting. The hands of the watch are now synchronized
Jan 29, 2013 | Tissot T-Touch T33159851 Wrist Watch
Hi, My Tissot touch watch quit, it was just over 2 yrs old, and I took it to the local Jewelry Store that sold them. They sent it off to their Jeweler and he replaced the battery. Now the watch keeps...
If the Jewellery Store was not an Authorised Tissot Repair Centre then it is likely that they have made a mistake - the T-Touch is the only watch in the world that has a touch screen - so they may not be very familiar with it.
It may be going into setup mode because there has been a new battery just installed - go through the procedure and see if it works. - Pretend it is like brand new and you have to set it up for the first time.
Dec 14, 2010 | Tissot T-Touch T33159851 Wrist Watch
Touch functions don't work. Stop watch occasionally works, all other functions shut down. Had ZERO assistance from Tissot after writing to their website and seeking tech support. Useless company, I'll...
Do you have a manual for the watch?
If yu haven't, then you can download one by going to their web site (tissot.com), click on "collections".
Then on "Touch collection", then click on "t touch", then double click on the t touch and details of the watch will appear. Click on "user manual" and then on "download" for your instructions.
Feb 07, 2010 | Tissot T-Touch T33759851
Tissot t-touch analog time is out of sync with digital time. How do I res-sync them?
This is the tried and tested solution from this very nice gentleman. Many thanks to him (Ha Bi):
  1. Press and hold on to the T button until it beeps
  2. Touch the middle of the screen to change digital display to unit selection
  3. Press and hold the T-button until "Synchronize" comes up in the digital display
  4. Use the + button and - button to align the hour and minute hand to 12:00.
  5. Click on the T-button again. Congrats, you're done!
  6. Enjoy~
Must see blog for all T-touch users
http://myhabi.blogspot.com/2008/10/tissot-t-touch-battery-change.html
Jun 04, 2009 | Tissot T-Touch T33759851
Need to sync tissot t-touch hands to digital time, and other functions
Paste this link into your browser:
http://www.t-touch.com/flash.html
1)Close available countries window,
2)Click on T-Touch, then choose Stainless Steel,
3)On the right side of the window click on film tab,
4)In the left box in the window find all the functions
5)Watch and listen to instructions
6)Smile
Do not forget to rate, please.
Jan 27, 2009 | Tissot T-Touch T33759851
Digital and analog display show different time
4)In the left box in the window find SYNCRO and click on it,
6)Smile
Jan 19, 2009 | Tissot T-Touch T33159851 Wrist Watch
Tissot t touch
there are sync instruction on the manual page on the web.
http://www.tissot.ch/data/usersmanual/138-en.pdf
1. Activate the Crystal.
2. Select the "units Mode".
3. Press and hold the "T" until it switched to "syncro" mode.
4. Now using the + and - move the hands to the 12 o'clock position.
5. Press "T" again to set.
Jan 12, 2008 | Tissot T-Touch T33159851 Wrist Watch
Watches Logo
26 people viewed this question
Top Tissot Watches Experts
Arturs Kalnins
Arturs Kalnins
Are you a Tissot Watch Expert? Answer questions, earn points and help others
