Suggest to be sure your Kindle is charged up. There are several generations of these devices. Search for reboot procedure online for example ... "reboot kindle 3rd generation".
Hello, All you need to do is find a toothpick or needle and there is a little hole in the back that says "reset" it will reboot the tablet and no data will be lost. Hope this helps!
However, sometimes when it locks up you can't tell because the screen goes dark, either ... it's already on but is locked up and thus won't charge or work properly. ... 15 minutes to make sure it gets enough charge, and then try turning it on again. ... If this tip (or anything else on my site) helps solve your Kindle Fire problem ...
To reset/reboot your Kindle Fire:
-With the Fire charged but unplugged from the charger, press and hold the power button for a full 20 seconds.
-When the Fire cycles off completely, press the power button once to turn it back on.
Press and hold the power button for fifteen seconds or so. If it prompts whether you want to shut down, ignore it and keep the power button pressed until it shuts off. Release the button, then press and hold for a second or two until it starts to reboot. Does it reboot and operate normally now?
There are two things you can try for this. The first is to reboot the tablet using the power switch. The other is to press in the Reset button on the backside of the Meep. If neither of these helps the situation, you'll want to contact the OSI call center.
