Question about Whirlpool Freezers
EV160NZTQ Motor runs continuously?
Upright Whirlpool freezer.
    Top Expert:
  • Whirlpool Master
  • 63,373 Answers
CALL A REPAIR SERVICE LOCALLY . NO DOUBT IT NEEDS FREON AND ONLY PRO'S CAN DO IT FOR YOU
Posted on Apr 22, 2019
SOURCE:
HVACRH20
  • 237 Answers
SOURCE: Whirlpool Freezer Model #EV150NXENOO
This one sounds like the defrost timer is not working and you are not getting a defrost cycle every 6-8 hours (or when needed). Another issue could be that air (moisture) is getting in from a leaky door seal, etc. and causing the freeze up. If you have a sealed system problem where the cooling coils are not uniformly frosted up then the defrost thermostat will not "know" there is an ice condition and therefore not go into defrost mode (same issue if the defrost t-stat is bad). After you have ALL the ice out of the unit it would be a good idea to take the interior rear cover off so you can view the coils. Start the freezer back up and watch over the next 1/2 hour or so to see that the entire coil is frosting up uniformly. If it isn't you may have a plugged system, a leak causing low refrigerant, etc. If over time the coils look uniformly frosted up you may have a defective defrost heating element itself (no heat, no defrost sort of thing). The defrost elements can be checked with a multimeter for continuity if you know how to do that sort of thing. It's hard to know a person's ability by these forums or if they can tackle certain test procedures.
Posted on Nov 13, 2006
fridgetech
  • 473 Answers
SOURCE: Whirlpool ev200nxr upright freezer not cooling.
It is most likely the relay and overload or the thermostat.  What is the complete model # on the sticker inside the freezer?
Posted on Oct 15, 2007
aborcass
  • 2651 Answers
SOURCE: Freezer runs constantly
not necessarily, is it maintaining temp? all food staying frozen? especially ice creams if stored in there. most newer freezers displace the heat generated while cooling the food through copper lines running through sides of unit, helps to cut down on air temp differences between the inside (0 degrees) and outside temp to prevent moisture and possible condensation causing premature rusting of unit
Posted on Mar 03, 2008
  • 323 Answers
SOURCE: kenmore upright freezer no digtal light no motor running
This could be a bad controller since you had a power outage, or even a bad motor. Look in your operator's manual and see if there is a reset button somewhere near the motor.
Unless you are well versed in electronics and have the proper equipment, you'll be unable to diagnose the control board anyway.
As a last ditch effort, which sometimes works, unplug it for about 5 minutes and then plug it back in. Make sure your thermostat is turned to the correct setting.
Posted on May 12, 2009
  • 389 Answers
SOURCE: whirlpool upright freezer evl209nbtq making noise
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Posted on Apr 21, 2010
Have a Whirlpool 15.8 cu.ft. Upright Convertible Freezer/Refrigerator Model EVL165NXRQ & use as freezer. It is constantly running with a humming or buzzing noise. What is causing this?
This unit has several fan motors, it could be one of them. If so you may have to replace the motor
"Always disconnect power before trying to repair any appliance."
Aug 12, 2017 | Whirlpool Freezers
Upright whirlpool freezer is not freezing. fan motor comes on, light comes on but is not getting cold. how can I trouble shoot the problem?
Could be the cold control thermostat that is the problem. You didn't provide your model number so couldn't get specific here. I did find another forum thread that might give you more clues: http://www.applianceblog.com/mainforums/threads/36458-Whirlpool-freezer-cold-but-not-freezing
Sep 18, 2014 | Freezers
Upright whirlpool freezer make loud noise when it comes on
This noise is the fan motor going bad because a bearing is worn out. You need to replace the fan motor before the compressor goes out.
Aug 28, 2014 | Whirlpool 19.6 cu. ft. Upright Freezer...
Why is the top shelf of whirlpool upright freezer not freezing?
Just had this issue. Freezer is packed usually & suspected airflow. Emptied bottom 2 shelves & vent strip was solid frost. Bottom 2 shelves were filled w/ solid roasts & other solid large items. Used blowdryer & currently waiting to see if it begins freezing top shelf.
Jul 03, 2014 | Whirlpool EV160NZTQ Upright Freezer 16 cu...
Freezer in unheated garage stops working
Check connections from your power outlet to your fridge. If the motor is not running check your thermostat. if not working check your compressor motor.
Feb 10, 2014 | Whirlpool 19.6 cu. ft. Upright Freezer...
My ice cream is melting and things have started to thaw
Turn the t'stat up to 9. You want to save the meat and ice cream. It sounds like you may be losing freon. Get it looked at soon so you won't come home and find meat soft and ice milk.
Mar 06, 2013 | Whirlpool EV160NZTQ Upright Freezers
Whirlpool freezer which is non frost is making ice and freezer stop working
I would first unplug the freezer, let it thaw, and then plug it in to see if the motor kicks in. If that is to no avail, then you could be looking at a bad motor.
Mar 09, 2011 | Whirlpool 16.7 cu. ft. Upright Freezer...
Door will no vacuum seal closed
Are you sure compressor is running? If it is make sure the evap fan is running. You should be able to hear the fan when you open the door. If ypou do not hear a fan running then fan has gone bad. 4390914 and approx cost is rediculous in my mind but it is approx. 150.00 to 160.00 . Crazy for a fan motor.
Jan 28, 2010 | Whirlpool 17 cu. ft. / 481 liter Upright...
Freezers Logo
48 people viewed this question
Top Whirlpool Freezers Experts
AJMAL KHAN
Spencer Field
Spencer Field
Level 1 Expert
Steve Allison
Steve Allison
Are you a Whirlpool Freezer Expert? Answer questions, earn points and help others
