Get cheap universal remote then factory reset in set up
With cable input connected to "RF in"on rear of unit make sure vidoe input is set to "Tuner". This will show up on the TV screen. Change channels numerically or using up/down arrow keys on DVR remote. Note there is a slight pause between changing channels.You probably will have to "autoscan" for channel setup/etc. If you say your TV set is old; it probabaly is equiped with coax
connection only/set TV channel to "3" or "4". when yot opt to play vcr/dvd it will override your
cable channel selected. Hope this helps!
SOURCE: harwa tv childlock code
For Harwa (also branded Logik) 54cm colour TV with remote RC-A07 showing blue screen with red lock in the corner, hold down "music" button on remote for 10 seconds to unlock.
If your unit is displaying DVD2 on the front panel, you will need to set the command on the remote to match the display on the unit.
Point the remote to the unit and press 2 on the remote. Them press system menu on the remote, you should be ok.
SOURCE: restore factory settings
To reset back to the 50 Mhz frequency on a Wii you press reset on the Wii and the down direction button/rocker on the wii remote. It works - I just did it!
