I manage to enter the system menu, I can set it off, but returning and calling the preset position 1 will start displaying info again.
SOURCE: display says hot ac disabled now car wont start..
Change fuel filter and pump or fill car to full Ac Hot Disabled is a Dummy code The problem is low Fuel pressure
SOURCE: How do I enter the code for my 2006 Honda Accord
Use the preset buttons to enter the five-digit code (I assume that you have that; if not, see below). When it is entered correctly, the radio will start playing.
If your vehicle is equipped with a navigation system, press and release the TUNE knob; the number ‘‘0’’ appears on the display.
If ‘‘0’’ is the first digit in your code, press and release the TUNE knob to store it.
If ‘‘0’’ is not the first digit in your code, turn the TUNE knob left or right until the first digit is displayed.
Press and release the TUNE knob to store it. Enter the remaining digits the same way.
If you make a mistake entering the code, do not start over; complete the five-digit sequence, then enter the correct code. You have 10 tries to enter the correct code. If you are unsuccessful in 10 attempts, you must then leave the system on for 1 hour before trying again.
If you don’t have the code, a dealer can access your code with your radio’s serial number. To access the serial number, turn the radio on. It must display ‘‘CODE’’, then turn the radio off. Push the preset 1, preset 6, and power buttons at the same time, then quickly release.
Hope this helps you.
Testimonial: "This was very helpful. I was having difficulty with what I should do when I saw the letters come on the screen spelling code while I was inputting it."
SOURCE: radio lights, steering wheel radio controls, and HUD not lighting
well, this morning they are fine, all i did was checked all fuses that had to do with illumination and radio. none were bad so no replacements were made, and now it works. wish i knew what i did.
SOURCE: HOW DO I TURN MY TRACTION CONTROL ON?
google 08 hhr traction control one of the listings says ss road test , it explains some of the traction control tricks.
SOURCE: multi-information display is blank
If you really plan on chasing this one down as a DIY project, you will need electrical diagrams from your car.
You can find these and a whole lot of other information here:
Haynes Avalon service manual
Even if you don't care to do your own maintenance, you can get an idea of the potential cost of a repair by looking into the complexity of it before committing to a sky-high repair bill.
We have a Haynes in each of three vehicles and they have saved us time and money.
I later figured out how you can ... You have to set how you want to show up at preset number no. 1. If the preset no. 1 has Display Info, you can set to preset no. 2-6 else, when you call preset 1, Display Info will appear in all the others.
Glad you were able to get it sorted - well done.
Tony
