Washer stops on 12 minutes and will not empty and spin. It goes off balance. Fixed balanced load, tries to empty. Stalls at 12 minutes.
SOURCE: Whirlpool lsq8500jq1 washer works and spins but
youre sump is blocked it is attached to drum and pump
SOURCE: load off balance error dc. Wont rinse or spin
Hello nikimiguel,
I’m an Owner like you I own the FAV6800AW and have helped many folks on this and other forums with this issue.
You are experiencing a classic malfunction of the One-Way Roller clutch bearings in the Clutch Pulley assembly. It sounds like you are in the early stages of the issue. I have put together a step by step maintenance process to clean up and re-lube the One-Way Roller clutches in the Clutch Pulley assembly see this post Clutch Fix Post for what’s involved. Look on the right top back of your Console. If you can give me the first two numbers of your serial number i.e. 10, 11,12, tru 17. That will let me know if your machine will use an Upper One-Way Roller clutch bearing ring. Mechanical skill sets to perform Clutch maintenance or replacement are basic, anyone can do this it’s just a tight work area. Your option is to DIY or call in a repair service. I would ballpark the repair cost at around $300 if they know what is wrong and how to fix. DIY the fix it and you may need a a can of WD-40 and Slick 59 One Lube cost around $10 if the One-Way Roller just need to be cleaned up and re-lubed. If the Clutch pulley needs to be replaced I will show you a site where you can purchase for around $60 delivered to the house.
See this most recent post of a forum member who is back in service with my process.
Standing by if I can help….Rich aka dh1200s
SOURCE: Maytag Neptune TL stops spinning mid cycle?
RF_Tim
I feel you have a Clutch malfunction a very common problem with the machine. If you want to DIY the fix see my Clutch Fix post.
FAV6800A/FAV9800A Service Manual for reference. Sears Parts Direct for reference.
If you need some additional help just shout back……..Rich
My washer does exactly that—at 12 minutes it goes off balance. Drain hose is clear, machine is balanced. It will run a whole load without clothes. With clothes, it fills, spins and then stops at 12 minutes.
