Question about Health & Beauty
Do you have a motor for biswift scooter. senchuan sct1-80a3s
    Top Expert:
  • Health & Beauty Master
  • 63,103 Answers
OF COURSE NOT WE ARE NOT A SELLING WEBSITE
Posted on Apr 24, 2019
2 Suggested Answers
SOURCE:
tbreeze47
  • 3083 Answers
SOURCE: looking to download a fault
There simply doesn't seem to be any information on the net available for the error codes.
I would suggest you contact Biswift support on the following webpage, and try to find out what's going on with your scooter, and what needs to be done to fix it:
http://biswift.en.ecplaza.net/
Otherwise, you could call around to a local repair facility to see if they could assist you in this problem. Often, they're sympathetic and will be glad to help any way they can.
Sorry I couldn't find a manual for you, I tried.
Good luck, thanks for using FixYa, and hope this helps you.
Posted on Sep 08, 2010
Front motor gets hot on my scooter
This scooter has only one motor. What is getting hot? Talked a couple min.ago to Shoprider they have no two motor Scooters out there unless it is decades old and that one had the motors in the back. Is this unit a Wrangler?
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
Aug 05, 2016 | Shoprider 889XLSBN Sprinter XL4 Deluxe...
Where can I get the 48v 500watt bushless motor for my e wheel E36 3 wheel electric mobility scooter
500 Watt 48 Volt Electric Scooter Motor
This link shows a 48 v. 500 watt motor, but you should contact them to make sure the motor fits your particular scooter. I hope this helps.....
May 01, 2014 | Health & Beauty
Rally scooter parts
The click sound is likely the electric brake releasing. If the brake is working and the scooter wont roll, then you engage it and you can push the scooter then you have a motor or motor wiring problem.
The Pride Rally is an older model whose electronics do not verify the motor is working prior to allowing the scooter to start. Please disconnect the motor wiring and check the motor's electrical resistance. It should read less than 3 ohms on a meter. If it doesn't, pull, clean and or replace the motor brushes if its a serviceable unit. If not - you may need a new motor - especially if the reading of the motor winding is over 3 ohms.
Oct 25, 2013 | Health & Beauty
Scooter Manual
Does the motor turn freely (i.e., are bearings good/bad)
Is the motor quickly overheating when you ride?
Is anything rubbing/ interfering with linkage from
motor to wheels? After you have lost power with the
scooter, immediately have battery voltage checked.
If low, then you have at least one bad cell in the
battery pack.
May 15, 2013 | TrendTimes.com Toys & Hobbies Evo 800w...
My mobility scooter reacts slowly or not at all from a dead start but once on motion seems ok it also seems to work better at a higher speed
Paul there can be brake problems and or motor problems with this scooter. I have had to replace both the motor and brake to get it to work properly. The brake can stick or drag causing the scooter not to want to start up. Ride the scooter for a while and feel the rear of the motor near the brake (be careful it can be hot) to see if it feels hot if it is then the brake is dragging and needs to be replaced if its not overheating then I would replace the motor. Hope this helps
Apr 20, 2011 | Pride New Mobility Victory XL 4 Wheel...
The motor is screeching and barely moves. Started periodically, now is constant. Drains fully charged battery within minutes.
When the motor is screeching and draining the battery, that indicates that the motor has most likely seized up and is not turning the axle properly, which in turn will drain the batteries quickly as the scooter struggles to move. I strongly recommend discontinuing use of the scooter for your safety until the motor can be replaced; contact the manufacturer for a service call to fully diagnose the problem and give you a quote. If your insurance purchased the scooter for you, they may partially pay for the repair.
Dec 19, 2010 | Golden Technologies Buzz Around 3 Wheel...
My batterys and charger are fine. but when i leave to go down the street it goes dead and the motor is hot. dont know what to do or where to take it and my money is stretched to its limit. can u help
Bonton you don't say if you are getting flashes on your console when the scooter stops. Did you purchase the scooter or did Medicare? If Medicare paid for it they will pay for most of the repair cost Since your scooter has an electric motor it will get hot when using it . How old is the scooter? If your batteries are good then you could be in need of brushes for the motor which are cheap considering the cost of a motor. you can call Repair Xpress @ 1-877-581-3733 to see if they have a tech in your area that can check the scooter for you and the cost should be reasonable. I hope this helps you. Let me know
Sep 12, 2010 | RTO IMC-Heartway NOMAD3 Nomad 3-Wheel...
Scooter moves approx 10 feet then stops led flashes 8 times then stops
Hi. 8 flashes is a fault code for a motor fault. It will be either worn brushes in the motor or faulty connectors to the motor. This fault code means that there is no circuit through the motor. Probably time to overhaul the motor. Most mobility scooters have plugs and sockets that are really to small to carry the amount of current that they do. Because of this, they sometimes fail.Good luck. Neil.
May 21, 2010 | Invacare Supply Group Invacare Lynx Large...
Health & Beauty Logo
Top Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Jeff Tilburn
Jeff Tilburn
Are you a Health and Beauty Expert? Answer questions, earn points and help others
