Red light comes on.... so there is power..... just nothing on screen and no sound
SOURCE: sharp aquos lc-37d43u tv
Same problem. TV worked night before and then would turn on but no picture or sound. Power and OPC lights blinking. I couldn't change the channel or get to the menu.
I disconnected the coaxial cable and the power for a few minutes and then plugged it back in (electric) but left the cable off. I got a message that it couldn;t get a signal. At that point I was able to change the channels. I plugged the cable line back in and everything worked fine... Good luck!!!
SOURCE: LC-37AF3X Sharp Aquos KCD TV
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The
internal circuits are jammed because of electrostatic
charges accumulating on capacitors, or because of a wrong voltage read
by the main chip on your monitor controller board. this started the
protection circuit.
2 The protection circuit detected a wrong
voltage or abroken contact, identified an internal fault and kicked in
, starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay
particular attention at inverter and power board, power board can be
inspected looking for bulged or leaking capacitors, then tested with a
multimeter. The inverter is more difficult to test , there is need to
read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
SOURCE: sharp lc-22sv6u won,t power on. no green light.
Sound like the TV is in protection mode. This happens when a part goes bad inside. the TV turns OFF to protect the other parts from being damaged.
Most commonly it's a power supply related issue. A bad capacitor or transformer on the power supply board is to blame.
For a do-it-yourself fixer with electronic experience, a Service Manual is the best for trouble shooting the problem down to the bad part. Normally, you can find it over the internet for less than $20.
SOURCE: Sharp LC 37HV4M Flashing red light on screen
hi,
your main board or powersupply is faulty
or
One problem involves the lamp cage being loose. The fix is easy. All you do is remove the lamp and put it back in, making sure everything is tight. I guess they had a problem at the factory, for a while, not tightening the lamp cage. After a certain number of heating cycles, the lamp quits making connection.
thank you for using fixya,rate my answer
vijay
SOURCE: my sharp lc 32d42u shut off and won't turn back on
IF YOU STILL HAVE SOUND I AM PRETTY SURE WHAT THE PROBLEM IS...
