SOURCE: Aastra 9110 Single Line Corded
Press the setup key and use the down,up,across arrows on the upper of the set below the window to find the date and time. Let me know if you get it done.
SOURCE: Need to adjust date and time on screen.
Just above the Hold button, with the Aastra name display, that is a sliding piece that will uncover your setup menu button. Press that and navigate to time/date settings.
Hope this was helpfull.
SOURCE: how to set date and time on aastra 5370
I suggest you consult the user manual.
You can get it in PDF format here : http://www.aastra.com/cps/rde/aareddownload?file_id=7959-13627-_MAS_XML&dsproject=aastra&mtype=pdf
Please rate if this answer helped.
Thank you!
Hi Sami Ilkka, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
Contact your System Administrator who is responsible for setting up the phone.
I just need to set the correct time on the phone. The manual does not mention this at all. In the settings menu I cannot find any alternative for time setting. All other models seem to have ways to do this?
I don't have a "system admin"...
