Sep. 6, 2005 - Manual Bremshey Orbit Control-S. View the Bremshey Orbit Control-S manual for free or ask your question to other Bremshey Orbit Control-S ...
Bremshey Fitness Replacement Spare Parts including Treadmill Belt Silicone Oil Lubricant Drive ... Bremshey Orbit Crosstrainer (Elliptical) Poly V Drive Belt (Meets Original Spec) ... Bremshey Treadline Control Treadmill Deck (Expert Brand).
take the cover off, if the front drive roller continues to turn when the running belt stops, tension the running belt by using the rear adjustment screws. One full turn on each side should do it. If the front roller stops turning but the motor doesn't, tension the drive belt by adjusting the motor back.
Unplug unit remove motor shroud so you can see the drive belt, plug in unit then start it you will be able to see whether the drive belt or running is actually causing the problem.If it is the running belt then turn both rear roller adjustment bolts clockwise in equal quarter turn increments until treadbelt stops slipping. NOTE: Be sure to run on treadbelt to ensure that the treadbelt does not slip while under load. Use 1/4" allen wrench
If the drive belt is slipping then to adjust the belt you must loosen the adjusting bolt on the motor frame then hold the motor by hand applied tension to belt then tight bolt you should be able to twist the drive belt no more then 45 degrees if you can repeat adjusting process.
It sounds like the belt is slack there should be an adjustment at the rear of the belt at either side of the treadmill usually a hex stud or allen key, if that doesn't help check the drive belt that comes directly from the motor which could also be slack or damaged.
