SOURCE: choosing a paper type
Un fortunately it is often a trial and error thing. I would try all "special settings", even cardstock ect.
SOURCE: trying to print on laser photo transfer paper, but
i tried to print on laser paper too but fuser is too hot. its melting the paper and getting jammed right? i got tired of printing on laser paper and converted to inkjet paper. this is much easier
SOURCE: My printer jammed when I tried to print a Tshirt transfer.
Most Tshirt transfer paper is fairly thick you could try a different brand and double check that you are printing on the transfer paper not the thin separtion sheets used to stop the paper sticking together.
SOURCE: Using a C3100 series HP inkjet printer, I'm trying
The steps vary by printer. I've got a c7280 installed and the options for me are to click Print > Preferences > Advanced > Mirror image. When you click on Mirror image, you change it from 'off' to 'on'. Click OK to save the setting and print. Be sure to change it back after you're done printing your transfers.
I am an HP employee. I do not represent HP on this site.
SOURCE: We have PIXMA iP2600 which
It's unfortunate that Canon don't provide separate Paper Feed Cleaner/Cleaning kit as HP do. Well, actually you can perform the Paper Feed cleaning from your printer itself. And of course, you can also perform it on the printer using a plain paper. Please follow this LINK, you'll find both the methods i.e. cleaning from the printer's menu and cleaning it manually. You'll also need something soft to wipe the feeder eg. cotton swap or an ear bud etc.. Don't use any cleaning materials eg. Acetone or Alcohol or oil, using so will create another problem. These cleaning methods are for Paper Feeder roller/s and the feeder.
Once everything is done, wipe the surface of the paper feeder with a lint free cloth and make sure it's cleaned and oil/dust free.
Sometimes if nothing is helpful and the type of paper being fed is very sensitive/fragile, we need to place additional paper below the paper but not as deep as the original is placed. In your case, after the transfer sheet is fed, put in another sheet of plain paper below it, but make sure it doesn't go deep inside, otherwise, the printer will pick up the additional paper instead of the transfer sheet. This is only just to help the transfer sheet slide in easier.
It's also very important to place the paper very carefully, so that the picker won't pick the paper with great force, instead to pick it up gently. You may also need to help it pulled in.
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
