Question about KLH Audio Players & Recorders
How do I connect my tv to the kLH receiverr - KLH Audio Players & Recorders
    Top Expert:
  • 8,537 Answers
SOURCE:
I have a KLH tv and and AT&T Uverse remote control. I see a red key on the bottom left hand corner of the screen. The screen is blue.How do I get that key off?I saw replies for people that have KLH...
I just had this issue and nothing worked! Then I pressed the "on demand" button on the ATT remote and the tv turned back on!! Hope that helps!
Aug 09, 2012 | KLH 13" TV
Is using the HDMI at the receiverr better
Unless you have a Blu-ray DVD player you should be fine using HDMI into the receiver first.
Feb 26, 2009 | Onkyo TX-SR705 Receiver
Component video signal between KLH DVD8350 & Vizio 32" PlasmaHDTV
If the Visio TV has more than one input, don't forget to use its remote to make sure the correct input is selected. It probably wouldn't hurt to put a DVD into the player, confirm its running from the front panel counters) and let it keep running as you troubleshoot. At least then you'll know there is an active video source once you find it. Another thing you can try is to put in a music CD, if the player accepts these too (most do). Then when you get the TV set to the right input, at least you'll hear music, and can then go back to trying a DVD.
I know you're using component video, so remember that unlike HDMI devices, the TV is unable to switch to the correct source automatically. So it may just be that you've never had to switch the TV's input source before. Good luck! :-)
Jun 02, 2017 | KLH DVD8350 DVD Player
KLH TV LOCKED
press and hold menue button on the tv, for more than 10 seconds to unlock
Nov 30, 2008 | KLH 13" TV
KLH DVD 221
My sincerest apologies. I was not made aware that you posted a direct request for assistance. It was only by chance that I saw your post.
To your concern should you still require information; most units would have a yellow, red and white connectors commonly called RCA. What is required then is a triple RCA to RCA connector as shown below. The yellow is normally connected to the video, while the red & white are for the R & L of the audio. An identical set would be on the rear of the TV unit henceforth the connection would be OUT from the KLH DVD 221 to the IN of the TV.
In some instances, a single cable is used to connect some models to the TV. This is called an RF patch cord and would look sonething like below. This would come form the RF OUT of the player to the RF/CABLE/ANT IN of the TV. Pls make sure that the style/form fits your units.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Aug 20, 2008 | KLH DVD8350 DVD Player
KLH R7000 Component Video Problems
I have lost my remote and instruction book where? do is it worth it replace
Mar 07, 2008 | KLH R7000 Receiver
Remote control
I used a GE Universal remote. The package has number 24921 and the instruction manual says it's a RM24912. Anyway, this model will control pretty much all aspects of this tv combo assuming we are talking about the KLH KDT133UY tv/dvd.
What you need to do is program the tv button on the remote to code 0029 which is a KONKA code. The real maker of KLH electronics. Then set the dvd/vcr button to code 0905. Now in order to access the tv menu, press the tv button then press the shift button which is the setup button. Then press the INFO button for menu. SHIFT, MENU, OK, and EXIT are printed with a black backgroung on the remote. Hince you need to press shift.
Took a while to figure it out, but here you go. Good Luck!
Nov 20, 2007 | KLH KDT133UY 13 in. TV/DVD Combo
Klh tv codes
Hi my name is Lawrence Harris and i need some codes
for klh universiral remote control.
Thank You....
Sep 21, 2007 | KLH 13" TV
23 people viewed this question
Top KLH Audio Players & Recorders Experts
 Grubhead
Grubhead
Gil Shultz
Are you a KLH Audio Player and Recorder Expert? Answer questions, earn points and help others
