SOURCE: bogs down at 25 30 mph 1st gear 45 in 2nd gear
This should fix the bog problem.
SOURCE: mitsibishi colt 97 stuck in 1st gear
Your link broke off. What might have happened is the car got stuck in 1st, and when you shifted to second, the link broke. Not too clued up on your car, but you probably need to drop the gearbox. On some cars you can take out the shifter without having to drop the box and still see if the link is broken. Good luck
SOURCE: 2000 mazda bogging in all gears especially in 1st and 2nd gears ?
Judging from what i know, the timing on the engine is probably a bit off, and i remember reading the exact same problem on another web site and that is also what they said. So just check the timing on the engine or have it checked by a mechanic if you don't know how to do it.
SOURCE: Transmission problem in E230 Benz
What you need to check is the transmission release bearing because if there is a clearance on the release bearing you will encounter this problem and also check the transmission oil.
I’m happy to assist further over the phone at https://www.6ya.com/expert/ramy_d9e7ebea3891f482
SOURCE: will only drive forward in 1st gear, 2nd gear and
It is propably the gear box. Take the seat off and you will see the gears inside. Mine works only in 2nd and not the 1st or reverse. But I know it is the gear box since my husband replaced the 1st one a while agao. Just need to find the web site for the repacement part. Only cost us about $30 to fix last time. Hope this helps.
