Cell Phones Logo
j
janome olivier Posted on Apr 21, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My phone is showing me fastboot mode. what dos it mean?
chris bauer
Level 2:
Habit-Forming:
  • Expert 135 Answers
  • Posted on Apr 21, 2019
chris bauer
Expert
Level 2:
Habit-Forming:
Answers
135
Questions
13
Helped
26727
Points
422
It thinks knows what its doing,
2 Related Answers
djbrown7288907
Dj Brown
  • 13 Answers
  • Posted on Mar 14, 2014
SOURCE: i bricked my xt907
Try to find an original copy of your phones operating system.
make sure it with your carrier. You my be able to reflash your phoneand save it.or get some one to do it for you.
go to a cell phone repair company/ or look for someone tech-savy in your local university who would like to earn some money.either way you have nothing to lose.
Michael Carroll
  • 742 Answers
  • Posted on Oct 28, 2014
SOURCE: My lg Phone says " fastboot mode started udc
You bricked it, don't try and flash it unless you know what your doing
My phone says "Secure boosting error! Error code : 1006" What do I do?!
Is it a LG phone if yes then follow the below instructions:-
This is a secure booting error! But, you would need download mode to fix it. See, LG has a special download mode that with a proper tool has a full root shell. It allowed me to grab a boot.img from another phone, and push it via download mode.
Are your LG drivers downloaded? Try fastboot. Sometimes if download mode crashes fastboot kicks in, and if you didn't wipe it you have a good chance of flashing it via fastboot.
Open your windows OS, CONNECT A STOCK CORD!!! It needs to be a data transfer cord, otherwise it doesn't get assigned a data port. It just charges. Open on your windows OS, Device Manager, and check for anything different. Like QCOM, or Qualcomm, or LG, or LGE. If you have a unknown device, right click it, and send a screenshot.
Jun 05, 2019 • Cell Phones
DNX FASTBOOT MODE
Fastboot Mode on Android from Kingo, which offers the best one-click Android root software for free.
Here's the link: https://www.kingoapp.com/help/fastboot-mode.htm
Aug 07, 2017 • Cell Phones
My Hisense U989 froze on the screen then I took out the battery now it doesn't want to power on. What should I do?
My hisense u989 wont turn on I tried to reset it but instead of showing reset setting it shows recovery mode fastboot mode and normal mode. please help
Apr 09, 2017 • Cell Phones
Tablet says, Entering DNX Mode: waiting for Fastboot command...
I would book mark these links. Below.
Copied from :
What is Fastboot for?
While in fastboot, you can modify the file system images from a computer over a USB connection. Fastboot mode can start on your device even before Android loads, even under the circumstance when Android isn't installed at all. And because of that, fastboot mode is useful for quick-updating the firmware, without having to use a recovery mode. In fact, it's the preferred way to initially install the recovery image. Once you set up, you boot to your phone to fastboot and you can flash image files to the internal memory. Flashing a custom recovery like ClockworkMod is a popular use case. The images you flash don't need to be signed with a particular key, and thus you should use care when flashing. It can also be used for developer operations. Things like erasing partitions and overriding kernel command line options can be done. And all this features make the tool very useful for developing hardware and software solutions, like unlocking the Bootloader of Google' Nexus.
https://www.kingoapp.com/help/fastboot-mode.htm http://forums.androidcentral.com/verizon-droid-dna/252896-how-do-i-turn-off-fast-boot-mode.html
How do i unlock the bootloader for my zte z970 4.4.4?
How to unlock bootloader in ZTE
  1. Enable Developer Option, Settings -> About -> Software Information -> More -> Now Tap on the Build Number 7-8 Times until you see a toast message "Developer option enabled"
  2. Go back to settings -> Now you need to enable the OEM Unlock by going to Settings -> Developer Option and Enable OEM Unlock and USB Debugging
  3. Download and Extract the Downloaded ADB fastboot Zip file on your PC
  4. Now connect your phone to Computer using USB Cable.
  5. When you connect your Phone to Computer, please wait until all the drivers get installed
  6. In your ADB fastboot folder open a command prompt window by pressing Shift Key + Right Mouse Click
  7. Now type the command in your command windowadb devices
  8. If you see a pop up to allow USB Debugging on your phone, Click OK
  9. Now type the command below to reboot your phone to bootloaderadb reboot bootloader
  10. Once your phone reboot into bootloader, make sure your phone shows the bootloader locked and then type the command below to make sure fastboot drivers are installed properly.fastboot devices
  11. This command will list the connected devices. If your phones serial number shows up you are good to go and may continue. If the phone is NOT listed this indicates that your drivers are not installed correctly. In order for you to continue you must fix your drivers so that your phone is listed under fastboot devices.
  12. If the phone has been recognized by the command above, proceed to unlocking the bootloader with the following command:Remember that this step will wipe EVERYTHING off the phone fastboot oem unlock
You can also check here
https://www.unlockninja.com/blog/how-to-bypass-google-account-verification-frp-lock-on-android-after-full-reset-or-forget-password/
WHAT DOES FASTBOOT MODE MEAN?
Fastboot is associated when you root Android. Here's a site that helps explain it better in detail: The Easiest Way to Install Android ADB and Fastboot Tools on Any OS
Hope this helps you get a better understanding of what it is.
3answers
Vtouch v705 is locked how I can reset the password
I read an article on how to reset the Vtouch V705 and although I have not performed this operation my self, you may want to investigate the following and see if it something you can work with that may help solve your issue. If this does not work or apply please reply and I will continue to look for possible solutions to solve your problem. Here is the quote on what you might try (if this applies) to possibly solve your issue.
"works well on chines android tablets! 1.Download the android tool. https://www.mediafire.com/?7se8s62sj1y5fpo2.extract and save to any location on computer2.open extracted folder and open software use the appropriate number for whatever job you would like to do.number 4 to reset Gmail lock, pattern lock, or password.when device reboots you may need to restart it a second time that's it all done. subscribe, like, share, comment.User Manual for Android Multi Tools v1.02bfirst device must install correct driver This program works with any Android device .Requires root and enable Debug mode or fast boot mode.choice 1-6,S,H can work with Debug Mode only.choice 7-9 can work with Fastboot Mode only.choice detail1.Check Device for check connection of device to PC.2.Reset Face/PIN Lock for reset face lock on android 4.1.x and PIN lock without lost data.3.Reset Face/Gesture Lock for reset face lock on android 4.1.x and Gesture lock without lost data. After device reboot Then you can draw anything for unlock.don't forget close lock in security menu4.Reset GMail for reset gmail login after try many time wrong unlock 5.Wipe Data for reset all data to factory setting.6.Reboot for reboot device to normal mode or exit from adb shell.7.Check Device On Fastboot Mode for check connection of device to on FastBoot mode.8.Wipe Data / Cache On Fastboot Mode for erase user datat and cache on Fastboot Mode to resolve freeze,stuk on boot logo or slow down device. That is often found in the CPU Spreadtrum SC6280/SC8810.9.Exit Fastboot Mode for reboot your PC or exit FastBoot.0.Go To Command Promt for entering DOS promt.you can use command in this soft folder And can return to the main program by type exitS.Software Info for info CPU inside,firmware version and etc.H.Hardware Info for determine the IC number of Gsensor,touch screen,Camera,WIFI and moreR.Report / Contact Me links to the specific problems of the Phase I program and a bookmark.D.Driver Download for loading the drivers in case you do not have the driver installed in your PC - See more at: http://celularmovil.info/video/view?videocode=okEyk5LrNDc&startpage=6#sthash.j9wiRuoL.dpuf
Please let me know if this works out or if you have any additional comments or questions. Like I said before I have not actually used this method myself so PLEASE be cautious when downloading and installing any type of software. Thank You!!
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
 Mikey
Mikey
Are you a Cell Phone Expert? Answer questions, earn points and help others
