Question about Hoover Washing Machines
How do I turn the Hoover elite 1210 washing machine on please ?
  • Hoover Master
  • 26,807 Answers
Http://www.hoover.se/en_GB/search-for-manual
manual is always the best place to start
Posted on Apr 21, 2019
SOURCE:
  • 209 Answers
SOURCE: Hoover elite 930 top loader washing machine
I am a recently retired appliance engineer of 20 years start with checking the other solenoid, the conditioner one, it may be that that is not working, and double check the cold one, remove the two wires and check for a circuit, it may be actually filing up initially with hot water without realising it, always work with safety remove the plug before removing panels etc if i have helped rate me please
Posted on Sep 09, 2007
SOURCE: I need to download hoover washing machine manual HNWL7146-80
You can try going to http://www.managemyhome.com/ and looking up the model # there.
Posted on Mar 15, 2009
  • 15 Answers
SOURCE: Hoover AL 120 washing machine won't spin
i would check the motor carbons it could be your problem if it fills goes through the programme until the end but has motor action
Posted on Apr 12, 2010
  • 327 Answers
SOURCE: how to remove the drum on hoover elite 940 washing machine
Hello,The motor mounting are usually the tensional method for the drum belt. You need a socket set to take the motor off and replace.Don't over tension the belt as it will ruin the bearings in the drum and motor.You should be able to deflect the belt by half an inch in the middle of its longest run with medium thumb pressure.Watch out for sharp edges on the cabinet when heaving on a bolt.
Thanks
Posted on May 23, 2010
SOURCE: How can I obtain any
www.2ndwave.co.uk/manual.htm
A manual above.
Also by contacting Hoover washing machines direct and asking for a copy of the manual. link below.
www.hoover.co.uk/products/18/laundry/22/washing-machines/ -
Posted on Nov 09, 2010
Hoover elite washing machine
FIXYA has no idea of any parts for hoover machine . contact hoover direct
Oct 23, 2017 | Washing Machines
I have a hoover elite 1210 washer. A wonderful washer , had no problems but the lid has discoloured. Wondering if i can obtain a new lid?
Spares Suppliers
You will need to type into your search engine/web browser '(make model number) washer spares' and you should be presented with a number of sources from which you can order. Alternately you could try telephone directories for spares suppliers but I would think the former would be more successful.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Jun 06, 2011 | Washing Machines
My Hoover Elite 1210 toploading washing machine seems to make a horrible off balance sound on the spin cycle - even when there is a small load on. What can I do to fix it?
Could be bearings or more likely the concrete weight at the bottom of the drum is loos give it a shake from under to check...Good luck
Feb 09, 2011 | Hoover Washing Machines
My hoover elite 1210 washing machine leaks with every load - overloading is not happening it even leaks on small loads. has never been serviced what service could we do on it to fix the problem?
could b drain hose, pump or main seal. could also b tub to pump hose. u need to find the leak first to repair it. does your machine have 3 screws holding the front panel to the frame or can u look underneath and see the pump.the screws r down the bottom at the front. please reply 4 more help.
Apr 26, 2010 | Washing Machines
My hoover elite 1210 won't stop filling once it achieves it's correct level
Information to water level sensor is via a small tube which, as the water level rises pushes air into the sensor. The tube could be disconnected....Not a big job but can be awkward....Find a tech......Nomess
Apr 13, 2010 | Washing Machines
Bad vibration during spin
Good morning! It's common to a washing machine to go out of balance everytime we exceeded the prescribed capacity load (as indicated in the enclosed manual upon purchase of the unit). the fitted new pump is not the source of such problem. Please try to review the manual of your machine and take note of the required capacity load which I think should not exceed 6kg. Best regards.
May 02, 2009 | Washing Machines
Hoover elite 1210 won't progress to the final 'spray and spin dry cycle'.
Hoping to be of help after the spin dry wouldnt work on our hoover elite 1210.
It would do the wash cycle fine but as soon as it needed to drain, it wouldn't.
My handy man (Husband) is great at fixing things and opened the front panel by undoing the screws.
Near the motor on the bottom left, there is a wheel/fan looking thing.
(Turn the machine off first)
He tried to spin the wheel but it would only move clockwise and not anti-clockwise like it is supposed to.
So he gave the fan a few spins clockwise before giving it a gentle pull outwards in which it loosened the wheel and was able to move anticlockwise again.
We then turned the machine on and it started spinning and draining the machine.
This machine is a work horse and I refuse to get another. They don't make them like they used to!!
Mine has a leak and we use a drip tray underneath at the moment. So long as it works. I am happy.
Hope this helps someone else with the same problem.
Sep 21, 2008 | Hoover Washing Machines
Hoover Elite 1205 washing machine
Does an Hoover elite 920 gearbox fit the hoover elite 1205 thanks
Sep 18, 2007 | Washing Machines
Washing Machines Logo
150 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
jimorris77
Steve F
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
