Computers & Internet Logo
Sarah Lockhart Posted on Apr 21, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Do next books come with IP addresses - Computers & Internet
SSN-MM3
Level 2:
Sergeant:
  • Expert 272 Answers
  • Posted on Apr 21, 2019
SSN-MM3
Expert
Level 2:
Sergeant:
Answers
272
Questions
0
Helped
80249
Points
947
No networkable product comes with an IP address, however this has a Wi-Fi network chip in it so it can get an address from the base station allowing it to connect
1 Related Answer
GeoffW1
Geoffrey White
  • 3965 Answers
  • Posted on Nov 04, 2015
SOURCE: How do I get a new IP address for my next book android 4.0 tablet it is saying unavailable
Most Android devices have an IP address only when they have connected to a router, usually by wi-fi (other times it isn't needed).
When connected go to the Settings menu, tap Wi-fi, then tap the name of the network you are using. The device IP address should be listed .
I have a XEROX WorkCentre 5638. How do export the existing address book to add addition email address to it?
This model does not support exporting of the address book. However editing of the address book is very easily accomplished by following the steps below.
We encourage you to use our knowledgebase http://mrc360.com/XeroxKnowledgeBase
These instructions link is here: http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=477,E=0000000000016114582,K=3962,Sxi=6,Case=obj(23672)
Solution : Add or Remove Addresses From the Public Address Book Using CentreWare Internet Services (CWIS) To add addresses:
  1. Open an Internet browser window on the desktop.
  2. Enter the IP address for the printer in the Address field, and then press [Enter] on the keyboard. The CentreWare Internet Services (CWIS) window will be displayed.
  3. Click on the [Address Book] tab.
    NOTE: If prompted, enter the username and password in the fields provided, and then click on [OK]. The default username is "admin" and the password is "1111".
  4. Select [Add New Entry].
  5. Enter the friendly name and the e-mail address for the new entry.
  6. Click on [Save & New] or [Save & Close].
  7. Click on the [Logout] link and logout of CWIS.
  8. Close the browser window.
To remove addresses:
    NOTE: If necessary, enter the username and password in the fields provided, and then click on [OK]. The default username is "admin" and the password is "1111".
  4. Click on [View All Names].
  5. Click on [Delete] next to the name you want to remove.
  6. Click [OK] to delete.
MRC
Cant get printer to send scanned documents to replacement laptop
you have to go into the address book and switch the ip to the ip of the current computer (open the run program type cmd the in cmd type ip config look for ipv4 settings the number you get is the ip you need in the address book of the machine
1helpful
Delete an x-employee email for an mx-2610N
Input the I.P. address into your web browser. Click on the address book tab on the left hand side of the page. Tick the box next to the desired ex-employee. Then click delete at the bottom of the page. Done :) hope this helps.
1helpful
How do I change my WD5000G032-001 external hard drive's IP address?
Very few external disk-drives _have_ an IP-address (the Apple Time-Machine is the exception). For those drives that do,
they obtain their IP-address automatically, by sending a 'request' out through their network-connection. A DHCP ('Dynamic Host Configuration Protocol') server on the network sends an IP-address to it. Most 'home' routers (wired or wireless) include the DHCP-server functionality.
So, the only way to change the IP-address is to configure the DHCP-server to always assign the desired IP-address whenever that specific device sends a 'request' for an IP-address.
Canon imagerunner c3100n Howe do I remove
Your in the copiers IP address into your web browser and go to address book and delete address , you can also add address's here. If you do not know IP address, go to machine, touch additional functions, system settings, network settings, tcp/ip, IP and write down #.
Can't print from Quickbooks Pro 2008 to HP 6500 All in one
You can install Deskjet 990c drivers to print from Quick Books
We need IP address of printer for this.
Please perform following steps to get IP address of printer.
On printer press Setup >>>> select Network >>>> select View Network Settings >>>> select Print Network Configuration Page >>>> press OK >>>> this will print network configuration page >>>> note down the IP address of printer showing on this page
Now you need to install Deskjet 990c driver
On computer click Start >>>> Control Panel >>>> Printers or Printers and Faxes
Click "add a printer"
Select local printer (uncheck automatically detect my plug and play printer) click next
Select LPT-1 port and click next
select manufacturer as HP and printer as deskjet 990c and click next
make printer name as Deskjet 990c and click next
Use as default click next
Do not share click next
Select "no" to test page and click next
This will show a new icon of deskjet 990c in printers window.
Right click on Deskjet 990c >>>> click Properties >>>> click Ports
click "add a port"
select "standard tcp/ip port" and "new port"
type IP address of printer in the column of printer name
type IP_IP address of printer in column of port name
device type "generic network card"
Complete the process by clicking next/ok/finish
Try to print from quickbooks by using Deskjet 990c icon
Wish for all success..
Harpreet_351
2helpful
D-Link DI 524 behind VNC access remotely - Need help....
Open a browser and type in htp://192.168.0.1 to access your router's web management interface. Enter the username and password (default is username admin and no password)
Go to the Advanced Tab and Virtual Server
Name=VNC
Private IP=IP Address of your Home notebook
Protocol Type=TCP
Private Port=5800
Public Port=5800
Set Schedule as you like
Enable the rule and click Apply.
To access you Home notebook from anywhere other than your house, go to http://10.0.57.46:5800
Next - remote management of the router.
The IP address that you enter on the remote management page is the IP address that is allowed to connect to the remote management. If the 194.145.183.83 is the IP address of your office, this should work. Be sure you apply a password or anyone going to http://10.0.57.46 will have access to you router, I also recommend changing the port from 80 to 8080 so that http://10.0.57.46:8080 has to be typed to access the remote management interface.
IP Address
Step 1 Open your web browser and type the IP address of the wireless router in the address bar (default is 192.168.0.1). Press Enter. Step 2 The default username is admin and the password is blank (nothing). Click OK. Step 3 Click on the Home tab then click LAN to the left. Step 4 Next to IP Address enter the new IP address. Next to Subnet Mask enter the correct subnet mask for the IP address entered. Enter a Local Domain Name if applicable. Step 5 Click Apply and then click Continue to save the settings.
Grand Canyon Tech
Grand Canyon Tech
