SOURCE: Casio TE-8500F won't start
On some cash machines there is a fuse that can burn out. Normally this fuse is located underneath where the cord go in.
Most cash machines when nothing happens means it is dead.
SOURCE: CASIO TE2200 CASH REGISTER ERROR INIT/FC
This machine has lost everything. It has either had a flat battery (internal rechargeable) from sitting for more than 2 months or it has not been set up from new with the dealer settings.-------------------------------------------------------------------------------------------------For those of you that have asked for a Casio TE-2200 manual, here it is: http://the-checkout-tech.com/manuals/cashregisters/Casio4.php
SOURCE: plz solve my problem casio
If the register is new, this is normal, it just needs programming.
Otherwise, it may have had a lock up.
Try this:
Turn key to PROGRAM mode.
Turn power off at wall.
Hold RECEIPT FEED down (may just be called FEED) - keep your finger on it.
Turn power on at wall.
Wait 5 seconds, then let go of RECEIPT FEED.
You should see "FFFFFFFFFF" on display.
Press SUBTOTAL.
Wait for print out.
Turn key back to REG mode and try it.
If anyone needs more information, the Casio SE-S300 manual is here:
http://the-checkout-tech.com/manuals/cashregisters/Casio_SE-S300_users_and_programming_manual.html
SOURCE: casio pcr t2100
This error code means Initialization or unit lock clear operation in progress. All that you have to do is complete the task that you were performing and it should go away. If you need the user manual, email me at [email protected] and I will send you the manual right away. Please put "casio pgr t2100 register manual" as the subject.
